Page 47 of 135 FirstFirst ... 3745464748495797 ... LastLast
Results 461 to 470 of 1341
  1. #461
    What system was he using? Progressive 2 stage, or on/off type?
    Sent from the Man Cave!
  2. #462
    Yeah a gallon is 6.5 minutes at full 600 ml/min. More research to do...
  3. #463
    Delaware
    Progressive, the snow stage 2 setup.
    Jason
  4. #464
    OK same as mine...
  5. #465
    I really like the octane on demand features of meth, but there are definitely some pro's and con's compared to e85.
  6. #466
    I was torn on e85. There are stations around, but the locations are not convenient for the meets/runs I do. With the meth I can always turn boost down to conserve it on lengthy runs. I still need to figure out if I am setting the W/M controller to boost, or Load base control. I would prefer load base, but not gotten into the flash part of this yet to make it happen...
  7. #467
    It is super simple to trigger a relay with a custom output on the flash ecu. You can use the pin 48 output settings. Now, I don't know if a way to set it up to be progressive or anything like that.
  8. #468
    Pretty sure it's not. What were you thinking of using to trigger it? Load? Though Greg and Jeff could probably figure a way to make it progressive.lol
    Medford OR
    One thing you can do to conserve water/meth mix with a progressive, is don't use any more than you need... I had mine coming in at 10.5 psi, and all in at 15, I was going through mix like crazy. Decided I didn't need to use that much, got it coming in at 14.5, and all in at 18 now. Cut my consumption in half or more.
  10. #470
    yes load
