Ass busting day! After 2hrs house work, 3hrs yard work, Brett showed up with beer. A mission was born!
After configuring, reconfiguring, and re-reconfiguring, there is no way I am going to get the meth bottle, washer bottle, and monster fuel filter all in that small space.So washer bottle is divorced from my life.
The FPR was another battle won. I need to get a line to remote the gauge, but it has a new tidy home. Will get pics when finally in place permanent.
Down pipe has gaskets, and clears everything! WOOT!!!!!!!!
Axles are in with no issues, fuel line ran from the tank to the filter. It could use 6 more inches, and a 45*, or 90* fitting for the filter to rear line, but made do.
Oh! And this!
This!
Tomorrow the drive shaft, cat back, and a shit load of other small things happening.
Sent from the Man Cave!
Looking good and looks like you installed your rotors the right way
Also, for washer reservoir it's pretty easy to feed from the rear. A few $ for tubing is all you really need. How often do you really use your rear sprayers anyway? lol
I want to tie mine into the switch on the column instead to get normal operation out of it. I'd prefer to tap into switch but it might be easier to just run wires from the connector under the hood back to the rear pump.
Plumbing the washer line to the rear tank is not an issue. Mine is done that way and it works great. You will need to add in a check valve into the line before the T-fitting under the hood. If not then when you hit your brakes they water will spray out. I used this check valve and it works great:
Amazon.com: SWF Washer Check Valve: Automotive
Wiring the rear tank to use the lever is simple also. Just need to cut the wire coming from the column level and tap it into the rear tank washer line by the switch. Really simple mod.
Next I'm going to upgrade my nozzles to the Galant wide spray pattern instead of the stupid stream we have now.
Thanks guys! I have no rear wiper anyway. I still have a lot of wiring to do in the cabin, so one more thing will not kill me.
Hey Coop,
Can you weigh one of the wheels you have with the tire on it please?
What size are the wheels?
They are +30 offset.
Sent from my SCH-I535 using Tapatalk 4 Beta
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
yes that, what he said
