Page 37 of 135 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 1341
  1. #361
    94 3500gt vr2? verified
    NC
    I had an issue like this a couple weeks ago. Hacked off the flanges from my old downpipe
  2. #362
    Yeah that was my first thought, but the second was my old one was stolen. Will take a look at the rear precat to see if it will work.
  3. #363
    May 2012
    Littleton, CO
    I'm going through the same growing pains with my DP. I picked up an extra flange for 25 bucks to have it welded to the one on the DP.
  4. #364
    Never finishes any verified
    Wake Forest, NC
    So is it the DP that is too short or the rear pre-cat? Looks like the rear precat. What kind DP is it and what kind of headers do you have on the rear?
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  5. #365
    It is the gctech rear o2/precat. The dp is the tanabe knockoff, and fit perfect before.
  6. #366
    Damn, that sucks to hear when you were so close.
    So what it comes down to is GC Tech rear o2/pre cat wasn't made right? Or could it be that maybe there was a 1g and 2g gc tech rear o2 housing made and you got the wrong model one?
  7. #367
    Apr 2011
    Mid-April 2011.
    Monroe WI
    I to ran into this problem. Stock and stock. Eith ebay downpipe. I ended up forcing it on. However its tight up against the rear subframe now. Not sure why.. fit great before
  8. #368
    Not sure what the issue is. The only different parts are the gctech front and rear mani with rear o2 housing. Same everything else. Will gitter dealt with, and fixed quickly.
  9. #369
    Member
    Chilliwack BC
    Cmon, they are td04's right?
    Why on earth would you produce headers for a stock replacement turbo & change the location of the turbos? , screwing alignment for everything else-
    I cant see the reasoning behind not jigging from the proper positions, ...freestyle?
    JesusHChrist I'd be pissed, & I have the equipment at my disposal to remedy the issues. Sorry to see this hasn't been too bolt-on friendly for you Bill-
    If you make a spacer for the back, it will screw the front. Best bet would be to remove both front & rear flanges(add length in rear & realign front flange)
    Bummer that you hacked into your crossmember for not.
  10. The Following User Says Thank You to Primus101 For This Useful Post:
  11. #370
    Sep 2012
    Decatur, TN
    I believe that information and picture belong in the Demotivating thread Bill, cause that's what it is to me
