Page 36 of 135 FirstFirst ... 2634353637384686 ... LastLast
Results 351 to 360 of 1341
  1. #351
    Feb 2011
    Scottsbluff, NE
    Um, I think we are talking about 2 different things... the "reservoir" is the vacuum tank that's bolted on the subframe in front of the transmission. Deleting it is as simple as unbolting it and capping the vaccum line that runs to it. Its purpose is to maintain vaccum for the clutch vacuum assist while the car is off. I think wingnut is talking about deleting the vacuum assist altogether, which would make the clutch much heavier (unless your vacuum assist didn't work already, like mine).
    1995 Dodge Stealth R/T Turbo
  2. #352
    Never finishes any verified
    Wake Forest, NC
    My vac assist works, but it leaks. So I removed the vac hose. Heavier pedal but still manageable on stock clutch.
    I'll be installing a Spec 2+ here soon so I may have to hook the vac assist back up if the pressure plate is that much stiffer.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #353
    Feb 2011
    Scottsbluff, NE
    My vac assist is completely dead, and I noticed zero difference between the stock clutch and the SPEC stage 2. Both were heavier than the RPS Maxx (AFAIK the heaviest PP available for our cars) in my 95 with a working vac assist (or the SPEC stage 3 or stage 4 in friend's 3Ss). Unfortunately my SPEC clutch only lasted about 20K before part of the kevlar melted and stuck to the pressure plate...
  4. #354
    My stock clutch was a bit heavy as the vacuum assist did not do much at all. I still may cap it if it does nothing by removing the canister, and lines. Actually the SB 4fe feels lighter than the stock clutch did, but that may be due to possibly needing more adjusting.
    Basically remove the canister, and hard lines, but for the line connected to the clutch master. Cut that line just after it passes behind the brake master. Remove the soft section at the Brake mater, and install a new piece of large vac line to loop around to the cut hard line.
    This is what I went off of. http://www.3sgto.org/3000gt-stealth-...reservoir.html
  5. #355
    Do not forget you NEED the one way valve hose connected so boost does not enter the system.
  6. #356
    Mar 2011
    oh five
    stop asking, texas IS a shiny penny.
    wonderful hell, everything looks so clean. i'm having thoughts.
    _isiah
    _isiah
  7. #357
    VR-3747 :D Not Verified
    Dayton Ohio
    i was thinking the clutch fluid resevoir... which is why i was so confused.
    yeah i have never had the vac assist thing.
    edit:
    however, i realize that my setup is incorrect now, so thanks for that link. i will fix it asap
  8. #358
    Well great news! I got the starter all hooked up, and found the shield/installed. Transfer case installed! Slightly disappointing news, I got the wrong missing bolt from mitsu. Ordered the short, needed the long. The Beard haz one coming in the mail right behind the oil cooler hopefully.
    OK, I'm movin along now. Next up the exhaust! Down pipe here we come. Gather the proper bolts, slather the copper anti-seize on, and am all ready for lift off. Missing the front gasket... Hmmm, looking around for a stray beer (they exist), when I spy the cat back! Woot I can use the one off the Y till I get to NAPA.
    Then F@CK! SH!T! PI$$!
    Pics uploading...
  9. #359
    Dayton Ohio
    the beard... definitely Emily!
    Good to hear. Car should be running by tomorrow at this rate!
  10. #360
    So I throw up the down pipe, looselyattach the front nuts, and go to the rear to see this!
    As you can see the O2 housing is too high, and the DP hits the x-member.
    5/8" gap WTF!! No matter how I fried the bacon it was 5/8" to make up...
    SO out comes the cutting wheel, and grinder!
    Perfect! ... ... ... NOT!!! Now the damn sway hits it. WTF I can't win.
    I think I can double/tripple gasket it, or try to find a spacer somehow.
