I can probably get it checked within a few days.
Sent from my SCH-I535 using Tapatalk 4 Beta
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
Well well well. If someone tells you that connecting the pressure sensor wire for the power steering is easy they are on crack, and you have my permission to smack the hell out em!
-end rant/
So as you can guess I did get the wire attached, the acc. belts on, and tight, alt is wired, the yank, tear, shred part of the vac delete is complete. Forgot to take pic of the pile-O-crap removed. Will get that later. There is still more to remove, but getting purdy!
OH, I bled the clutch, but not quite sure if it is where it needs to be. I used a vacuum bleeder, and the bubbles seemed to never end. I need to adjust some of the play back out of the peddle. Should watch Jack's video again, and hit it one more time.
Shoes with laces!
Sent from the Man Cave!
Crapo Elditcho!
Cleaned up the injector wiring! WOOT!
blah blah blah
Hurry up
^^^ lol
