Page 124 of 135 FirstFirst ... 2474114122123124125126134 ... LastLast
Results 1,231 to 1,240 of 1341
  1. #1231
    Sep 2012
    Decatur, TN
    Negative. Journal bearing, shouldn't need restrictors IIRC. Might as well go ahead and replace the oil pump since it's all back apart. Or replace/rebuild the bypass.
  2. #1232
    New pump was delivered a couple weeks ago. I have a rebuild kit for the bypass as well, but not chancing it.
  3. #1233
    Medford OR
    while you have the crank out, air check the oil squirters... They are a ball and spring popoff valve, and should squall pretty loud when you pop them off with air pressure. If they are stuck, or the springs are damaged, they will just hiss, and not hold any pressure back.
    If that block was hot tanked or oven baked, they probably should have been replaced.
  4. #1234
    Will do Thanks Larry. He said he removed (assume before tanking) and cleaned them.
  5. #1235
    Durham, NC
    What's the condition of the pump pickup and screen? Was it replaced? Any chance the tube is leaking at the flange or strainer?
  6. #1236
    Ah, on my phone looked like he bored through the cylinder wall
  7. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  8. #1237
    Quote Originally Posted by mdcrose View Post
    Pump had around 3k on it. Wear specs are a couple pages back. Pickup is new.
  9. #1238
    After looking at them I see what the fuss was about.
  10. #1239
    Medford OR
    Good to hear he addressed them... They're probably fine then. Too many shops wouldn't have paid any attention to them at all. I've just seen too many of them with damaged springs, and/or full of metal.
  11. #1240
    All squirters are functioning as should be.
    I pulled the pump apart again to see what the flow path is in these things. The only two things that can effect pressure is the bypass, and wear. Though the tolerances measured are fine, I measured the wear marks in the backing, and cover where the gears mesh. They are worse than first thought, but I still do not think there is enough leaking to lose 20psi at idle.
    The cover .017" wide/deep with the second being about .011" wide/deep
    The back is about the same
    Still no smoking gun, mind blown...
    Taking the crank, cradle, 3 pistons, and all bearings to the machinist to get his thoughts on them. Will take the pump too...
