It does look fubard. It's the oil on the cylinder walls that make it look that way. lol Did not see that on the phone when posted...
Clearances
Once again the view pains me...
A big thank you goes out to Brett (VR4tune) for motivating me continue my affair with her. She has had me so pissed I wanted no part of it anymore.
At this point the only thing I have come up with is the damn pump is bad even though the tolerances were not too bad.
Any other angles on the issue are welcome...![]()
Both your oil pressure sensors are fuckedwhere they replaced after the last spun bearing?
Waiting install
Build Thread
No bearings have been spun. One sensor is new aftermarket, the other is oem original. The bearings show no sign of heat either which is odd due to the pressure being as low as 8lbs.
The oil pressure issue was pressent the last tear down as well. I just assumed it was from fuel pollution in the oil thinning it.
Is it totally out of the question to send her to Chris?
I know it would be expensive but maybe cheaper then to keep chasing
I'm stumped myself. At this point Bill you just need to take your time and explore every option. Maybe Ray P. could chime in with his extensive experience. On the plus side we had that bitch out fast and on the stand without working very hard.
I think it must have been the bypass stuck open though it seemed fine when inspected.
Is there restrictors in the turbo feeds, or the chra?
