Page 118 of 135 FirstFirst ... 1868108116117118119120128 ... LastLast
Results 1,171 to 1,180 of 1341
  1. #1171
    There are 2 sending units, the gauge is on the pump right next to the one th ecu see which is in the block. They are reporting the same pressures as when the gauge reads ~10psi the dummy light flickers. So with your logic it may be the pump afterall?
    Edit: I see, so possibly the damn restrictors...
  2. #1172
    Looks like I will be checking for bearing damage, and if there is the whole lot comes out again. If no bearing damage I will pull the front head to see if the restrictors are present, and go from there. This is so fun!
  3. #1173
    well that sucks Bill
    Yes, but on the bright side I am not getting a lot of feedback on being a dumbass!
  5. #1175
    Well, it seems I need some bearings.
    #4 left, #6 right
    I need a new socket for the head bolts, the last one busted. (cheap pos all I could find local) Front head will come off to see about a missing part. If the front is there I will pull the rear. If the rear is there the machine shop just got a reprieve from assault, the engine comes out for bearings, and may need a fucking crank.
    I am ussually the guy that rolls with the punches, but this is getting stupid.
  6. #1176
    really looks like oil starvation. What did you find inside the pump?
  7. #1177
    Got disgusted, and left the shop. I will pop it open tomorrow nght after I get a socket for the heads.
  8. #1178
    Sorry Bill
    god damnit.
  10. #1180
    Oct 2011
    Sundsvall, Sweden
    I'm really impressed with your determination Coopkill.
    When I had to pop open my gearbox for the third time this years due to bearing noises I felt like throwing the whole thing in the sea so I can understand how you must feel about your engine.
