Page 11 of 135 FirstFirst ... 9101112132161111 ... LastLast
Results 101 to 110 of 1341
  1. #101
    Front bar end link are the $11.99 Diamante Moog links. Much beefier than the $45 oem links! Upgrade in quality, down grade in price! How often can you find that? I used them instead of the heim joints that can with he sway bar. Grease-able, and dust caps. ftw
    Those damn sway bars are a lot larger than oems! Can't wait to test them out in the corners...
    I bought new ones from Moog and they sent me to different ones, one had lube fittings and the other one didn't. Same with another part, looks and is different but the same part. I was very disappointed.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    Well Brandon (Vr4Thunder) came up with influential motivation. (Beerz)
    I got the pump hanger all together, and installed.
    We then tackled these.
    which sway bars are these? The redesigned suppose to fit right addcos?? how well did they fit? considering a set for the vr4..
  3. #103
    GREASE BUNNY
    VA
    Good progress today!
    It takes time. Ask me how I know.
  4. The Following User Says Thank You to Granny For This Useful Post:
  5. #104
    94 3500gt vr2? verified
    NC
    Wow, Looking great
    Subbed
  6. #105
    The Panda Not Verified
    Washougal WA/Portland OR
    Quote Originally Posted by Blackmount View Post
    Addco is right! I just installed a pair too but haven't driven the car yet but fitment is good so far. I will post more when road tested.
  7. #106
    Just remember to check clearance to axles throughout suspension travel. Really my only beef with my front bar.
  8. #107
    Will do Chris, thanks.
    As Brett said they are the new Addco redesign. Installing was pretty easy with 2 peeps. I did not use the spacers in the rear, and 1 on the passenger side in the front to clear the sub-frame. The key to installing the mounts to the frame in the front is to bend the pre-bent hardware back to almost flat. The bolt will bend it to the correct angle when tightened. If you do not do this, you will not get a socket on the bolt as the bend/angle is in the way of clearance for access.
    I also about crapped myself when I seen the angle that the end links needed to be installed at, but they went in pretty easy. The key being using a jack on the a-arm of the first side installed to align the second.
    I also have changed the price of the end links. The brain is old! They were $16.56 per, not $11.99. There are some as cheap as $11.99 on Rock Auto though.
    MOOG Part # K80186 $40.67 Shipped More Information for MOOG K80186
  9. The Following User Says Thank You to CoopKill For This Useful Post:
  10. #108
    That sucks Paul. I have never had issues with Moog, but that is ordering through venders, and not them direct.
  11. #109
    yeah, i also bought moog through rockauto. no problems that way.
  12. #110
    Mar 2013
    Vancouver, WA
    Hey Bill its Brandon, finally got set up on here. Thanks for having me over, looks like I might be a go for this weekend too
