Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: So I went to start tuning the ecu and...
    my front Low fuel trim is at +12.5%, and my rear low fuel trim is at -12.1%.
    um, LOL.
    *throws in the towel*
    i can supply a log but this forum doesnt allow .csv files to be uploaded.
    not sure what to do. if i increase the fuel, it'll fix one bank but make the other worse. and visa-versa.
    the weird part is that it seems to idle just fine at 14.7.
    where the heck do i even start with that?
    I lack color... verified
    Aug 1998
    FPR over run. It does that to your trims.
    VR-3747 :D Not Verified
    Dayton Ohio
    i have almost the exact same problem except im adding fuel, and its not changing the values at all. i do not have any overrun, i can guarantee that. suggestions?
    i have an aftermarket regulator.
    Dayton Ohio
    Quote Originally Posted by Keyan View Post
    as do i. an aeromotive, about 42 - 43 psi base
    2004/5?
    SW Connecticut
    Similar over here, aem fpr.
    Sent from my Motorola Atrix
    oh good, its not just me. lol
    Dayton Ohio
    i need to figure this out asap. need to get the car tuned today. i change fuel and reflash, but its not changing the fuel trims
    Aug 1998
    What do you mean by this exactly? You're changing the fuel table?
    I always assumed this happened in my car due to FPR over run, but it appears that's not the case with all you guys.
    Aug 1998
    Also, it takes 16min for the long term trims to update. Make sure you're changing the MAF comp values with-in the correct HZ range of the trim you're trying to adjust.
