So i have owned my 3kt for about 4-5 years now and ever since ive had it its had a weird clutch issue. At least one time a year i had to add more fluid to the reservoir, which makes me think that it has a really slow leak in it somewhere since i drive it every day. But recently in the past year its developed a new issue. Every couple weeks the pedal seems so just stiffen up and there is no play in the clutch, its just all pressure. Also when this happens my clutch likes to slip if i try to give it too much power, like the clutch is not fully engaged. This can be fixed my loosening the adjusting screw and turning the adjusting rod one way and the pretty much back to its original position that i had it in. (factory recommended play).
I bought the car with 87k miles on it and at that time the master and slave cylinders had been replaced not only once but twice already. The previous owner gave me a binder with all of the previous work to the car.
It seems to me that they never really fixed the original problem with the clutch system and this could possibly be causing all of the issues. Any suggestions on where to look?
