Results 1 to 10 of 10
Thread: Polyquad Head Porting
    Sep 2012
    Decatur, TN
    Curious if anyone had tried this with the platform yet. Tried searching for it on both forums but to no avail.
    For those who have never read the article: Polyquad Article - MotorTech Magazine
    I know a few DSM guys ran something like this, and I believe the SRT4 ended up using a design very similar.
    In short, using different sized valves and port shaping to induce a swirl can add low end power and torque. A highly modified 4g63 that this was tested on picked up almost 100hp and torque on 5lbs less boost. Reports averages of around 7% increase in torque and hp throughout the RPM range would mean quicker turbo spooling. Not sure what it would cost to get a set of heads done, but depending on what the price is, could be comparable in power to most of the ported head options we have now or maybe better.
  2. The Following 2 Users Say Thank You to sergechronos For This Useful Post:
  3. #2
    Banned J. Fast's Avatar
    Four different sized valves to promote swirl... very interesting. If I had more rep to give today I'd hand you some (this will come tomorrow). Thanks for posting the article. Was very long and needs more pictures but was a good read.
  4. #3
    Medford OR
    Interesting read... I've seen many versions of high swirl designs over the years, and it's no secret that it's the key to an efficient engine. This guy definetly put some thought into his version. It would certainly be worth some testing.
  5. #4
    Sep 2012
    Decatur, TN
    Much obliged sir. Price in the article seemed rather rather high (600-800 per cylinder plus the cost of valves), but I will try calling the machine shop listed and get a quote. I imagine it won't be cheap, but 4k for a set of heads with no proven record for the platform is would be a bit out there in my opinion, but if the numbers are accurate it could bring a lot of new options. I'm sure IPS, 3SX, DR, etc could probably copy the concept if they had a set that were ported to work with, or even just by following the instructions and pictures get a basic ballpark. I'd love to hear one of them, or someone who has finished their engineering degree, chime in on if this makes sense.
    It'd be nice to have a factory car (or close to it) and run a set of stockers, a set of poly quad style porting with standard valves and a set with the recommended valve changes and see the difference in power produced. Depending on the power difference, the savings from not having the valves oversized could probably trim 700-800 from the machining and not having to buy the valves and bring it down closer to the price range of current porting options (although still quite high.) DR alleges 40hp improvements on their Stage 2 if your turbos can move enough air to utilize it, although 7% benefit for factory motor would be 20% more hp and torque throughout the RPM range and the 7% came on a Fiesta, so we may see larger improvements being boosted considering that Eclipse gained over 10% while running 5psi less boost. Can't expect anyone running 9bs to pick up that horsepower, but can probably figure around at least 10% gain with same boost levels I would think while improving behavior through the RPM range with a broader torque band.
  6. #5
    neat idea, but like said above $5400 is going to be a bit of a stretch for ANY heads, even if they were proven.
    Especially when we are talking mostly about street guys on here and most of us do not run our turbo setups so hard that an extra pound or 2 of boost is not available to use.
  7. #6
    I don't bite
    Southern IN
    Great article!! Would love to send a TT and NA head for their review and recommendation but $1000 per cylinder is not budget friendly. Unless you are chasing every last hp, I guess I'll just turn up the boost a couple psi
    Great idea though. Better off boost tq, high end, plus should spool a turbo a little quicker. A lot of upsides with no downsides so far, is awesome.
    Edit: didn't mean to echo forest. Got distracted and took me awhile to finish my post
  8. #7
    1993 rt/tt Not Verified
    wa state
    Subscribed...
  9. #8
    Sep 2012
    Decatur, TN
    Been a while, unfortunately the money I had set aside to see about getting a head done from the company listed have gone to crap having to rebuild my bottom end and turbos. I have found though that other people have utilized similar port and chamber shaping to achieve similar results. The link at the end has pictures that better show the biasing in the shaping. Still not sure how doable it would be for our cars. The concern I have would be that our heads are designed for tumble flow vs swirl flow IIRC. While tumble and swirl can be more effective than pure tumble in effecting rapid and stable combustion under lean mixture condition, you go too far and you can end up with worse heads than you started with. Not sure how the tumble swirl combo would impact our spark if done properly, maybe could help reduce spark blowout?
    Given the option for just reshaping the chamber and ports for bias rather than new valves would reduce the cost significantly since you aren't needing to get new valves and all the extra work that goes into it. Rough guess based on price difference between Stage 2 and Stage 3 heads from some of the vendors where the big difference is whether or not they have the 1mm oversized valves, could reduce costs greatly. Citing the original document they alleged about 500-700 per cylinder plus 200 for valves per cylinder. Those numbers are rather high, and perhaps are specific to the ones they ended up using in that 4G63 due to the high heat for the valves (Ferrea aren't 200 per cylinder that's for sure.) With that in mind, you could drop it to maybe 400-500ish since you don't have to do everything associated with oversized valves just with specific port shaping. That would put these on par with (cost wise at least) stage 3 heads, and would make for an interesting comparison. Or to see one of the vendors give it a shot and let us know what they get. Costs would obviously be much cheaper once you get past the one off stage. I'd love to see a car do back to back runs with stock TT heads vs Stage 2 heads vs Stage 3 heads vs the stock sized port biased heads vs poly quads if ever possible.
    At the very least, would settle for back to back stock vs stock port biased heads vs stage 2 heads. If the numbers still hold true for 7% more hp and torque throughout the RPM range, these could make for very streetable heads even without cams. All speculation though. If one of the vendors (or someone else with porting experience who understands everything associated with this idea) wants to try it, I'd gladly send my extra 1g TT heads to get ported for trials.
    Holler: Poly Quad Revisited.
  10. #9
    This sounds good , but he does benefit from reducing the heat transfer effect to the engine by appling the thermal coat means he is running colder and there is many advatanges to run a colder combustion chamber, I got a set of heads sent to polydyne in houston to have the cambers and ports coated is a stage 3 race port head.
    1990 6465 600hp DSM
    1991 Stealth 3.5L on the works
    1993 Vr4 Rebuilding from ground up
    GCTech Motorsports
  11. #10
    Sep 2012
    Decatur, TN
    Well the coating was applied to the Mitsu head that was raced which saw gains of 14% running wrinkle wall slicks. The car most likely also had some form of ported heads on that prior, so it's hard to get a good baseline.
    The 7% figure that I quoted in here was from a 2.0L Focus that didn't get oversized valves,coatings or any welding for serious reshaping on it (bottom of page 4 into page 5.)
    The GM heads graph provided on page 4 are a bit more complex since the other heads are 2v heads, not 4v. But the 4v Polyquad heads have the same torque and HP up to 4k rpm, and then greatly exceed it beyond that.
