Page 18 of 32 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 314
Thread: Is our suspension setup correctly by aftermarket strut MFR's? Is the bias correct?
  1. #171
    Oct 2011
    Sundsvall, Sweden
    Awesome pics!
    Also like the hood, may I ask where you got it from?
  2. #172
    ~2006
    Pittsburgh, PA/Wheeling, WV
    184MPH!? That is fast..
    Also, what is the thing sticking out of your hood?
  3. #173
    Thats the tow hook
  4. #174
    To be fair, it's a loooong straight. I was just able to carry more speed through T3 which lead to the faster straight time.
    Yes, that's the tow hook. The kind that poke out of the front of the car is pretty much a spear should you T-bone someone. There's even talks of someday banning them. I personally didn't want to ever spear someone I went that route instead.
    www.stickyvinylgraphics.com
    Custom Stickers & Graphics
    www.chumpcar.com
  5. #175
    The hood came from Chaser Aerodynamics from about 3 year ago? Something like that...
  6. #176
    Oct 2011
    Sundsvall, Sweden
    Quote Originally Posted by Erron Spalsbury View Post
    Thanks for information, I have to get a quote from them.
    Have you had to reinforce the hood in any way in order for it to stay in one piece at 184 mph
    I've seen a few stories of CF/fiberglass hoods not being stable at high speed.
  7. #177
    I haven't. I also don't use the stock latch but dual OMP hood pins.
  8. #178
    Banned J. Fast's Avatar
    Yo E, what did you collect for tire data? What were your inside and outside temps on the corners? Dam you pushed that tire like mad. Haha, you totally killed it! I was hoping to see you and Hal go at it on the straightway. Good times man! Looks like you only have a few lil bugs left. You coming back out on Sunday?
  9. #179
    16 degrees higher on the outside edge with the point and shoot IR. Not really the correct way to measure temp but I didn't have access to a probe. They didn't really go over temp, I just didn't have enough camber dialed in. No bluing on the tire so that's good. I think these tires were just about done anyway. I just pressed too hard down in Danny's Lesson to feel the load out on the heavy side of the car and lap after lap took it's toll. I'll dial in more camber and have at it again. I thought about running the cam bolts but I think I'll just hoggle out the pillow ball mount and tilt the whole enchilada. I think I'll even drop the car another inch or so as I never even came close to hitting the fender with the tire.
  10. #180
    Want to see something crazy familiar?
    The pic above is from a 14k front and a 10k rear. The alignment is good. I put in a bump steer to correct the shouldering . Look how bad I was pushing the tire. There's a ton of understeer bias. . I changed the rear spring rate to match the front so 14k front and rears. I shifted the bias to neutral and stopped pushing the tire. You can see it in the tire wear. I also even'd out the tire temp across the tire. I changed the tire wear issue in the suspension alone. Here's a pic of the same type of tire on the same corner with a 14k front and rear with a dual 200lb helper 1" from bind.
  • History
  • Information
  • Groups
  • Events
  • Resources
