Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 69
Thread: LtWt Flywheel, Who's Runnin one?
  1. #41
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    Yeah, searching for RPS and Fidanza failures, they both come up, Fidanza more so, though. Still undecided, it seems there's at least a few failures for each
  2. #42
    7/10/06 or somethin
    Bend, Oregon
    My concern with the Comp flywheels are, they seem to run quite a bit lighter than the others, 15-16lbs seems averaage which might be the magic weight? I DO like the idea of a once piece, less chance for failure of parts
  3. #43
    Quote Originally Posted by Nihil View Post
    It is 2 lbs heavier than the fidanza.
  4. #44
    7/10/06 or somethin
    Bend, Oregon
    Here's the info I've gathered real quick:
    Clutch Masters FW-622-AL 16 lbs aluminum
    Clutch Masters FW-622-SF 16lbs steel
    Competition 2-622-ST 14 lbs steel
    Competition 2-622-STU 11.5 lbs steel
    Fidanza 161301 12 lbs billet aluminum
    SPEC SD03A aluminum no info
    SPEC SM03S steel no info
    RPS billet aluminum 12.5 lbs
    stock 22lbs
  5. #45
    Fidanza has been making these flywheels before RPS, so there might be a lot more Fidanza out there in the wild.
    98 3000GT VR4
    91 Stealth TT.. Retired
  6. #46
    The Aluminum flywheels are literally half the mass of the stock flywheel, therefore it would heat up much much quicker than stock, thereby limiting the amount of launches you can do in a given time-frame. One benefit of the aluminum however, is that it cools down faster than steel.
    I think it's pretty obvious that if you are making big power and drag racing then a steel flywheel would be a better option. On a BPU car cutting 1.7xx 60", I don't think there should be any problem unless you have a slipping clutch.... at least I never did.
  7. #47
    What HP numbers are you guys puttin down, guess I shoulda asked that too, as gump had a good point with the HP/weight
    This FS came on the FW when I bought it so I don't know the history.
    Quote Originally Posted by drew0u812 View Post
    This
    Avoca, NY
    The point is he is not running the car AWD, it is not been AWD converted. An AWD car is much harder to launch.
    It is obvious you are going to run this thing no matter what I say, so go for it.
    Just to make it fair I was launching on slicks and prepped tracks which is probably equal to launching an AWD in most cases.
    It looks like the issues come from hard launches which if you're doing a bunch of them a lightweight flywheel isn't ideal anyways.
  9. #49
    7/10/06 or somethin
    Bend, Oregon
    Those are all good points. Anyone have an opinion on the Comp clutch flywheels? They're one piece steel, I've been doing just a general google search for reviews and the Fidanza definitely has more failures than any other, but like said, they've been around longer too. RPS had minimal search results and all the comp flywheel installs were on small cars with irrelevant information.
  10. #50
    Quote Originally Posted by Maximal View Post
    your car doesn't weigh 3800 lbs I hope.
