Results 1 to 10 of 16
Thread: Timing question
    VR-3747 :D Not Verified
    Dayton Ohio
    Timing question
    I am using a flashable chrome ecu for those that dont know. I have 1G heads on my 2G engine (2G wiring harness and car).
    my question is: the timing reported by evoscan... is that accurate? what if i adjust the CAS sensor on my rear head, how does that affect the timing values reported?
    i know a lot of people have reported timing drifts at higher RPM's with a 1G CAS/2G engine setup, and was curious what everyone thought about this?
    Low & Slow verified
    Fortson, GA
    Accurate, yes. Every load cell I hit has spit out the exact same timing number on Evoscan. Drifting due to CAS IDK.
    Jeff
    I lack color... verified
    Aug 1998
    If you installed the 91/92 photo sensor it creates a latency issue as the RPMs increase. Timing at idle will be about spot on, but the faster you rev the engine, the father off it becomes. Its usually off by about 4 degrees by redline.
    People try to make a big deal out of this but the truth is, you can tune the engine around it just fine. Your numbers may be a little different than the guy who has an identical setup to you and running the 93+ haul sensors.
    This latency isn't something you can see with evoscan. It can only be observed with a timing light.
    Aug 1998
    Wait, if you're running a 2G setup why is this a concern?
    Aug 1998
    Quote Originally Posted by kywhitelightning View Post
    There are a few modifiers throwing in the timing calculation before final spark advance is sent to the PTU. Coolant temp, air temp, TPS tip in, idle.... The timing map is just the first part of the calculation. Many times your final advance will be a little different from the map due to these modifiers.
    Dayton Ohio
    greg, i have 1G heads, a 2G car/wiring/harness... that IS my concern. i want my car to run well, as expected, and reliably that way.
    the drift is a concern for me, and im not sure if it runs more or less timing up top.
    so the answer to my question overall is that the timing DOES drift with a 1G CAS sensor and 2G engine/wiring
    Aug 1998
    1G/2G heads don't matter. They are inner changeable.
    If you're running 2G sensors, the CAS latency isnt even a discussion as you are running the exact same sensors as a 99.
    If you are running a 91/92 CAS its still a non-issue as your tune will never "drift". You call for 22 degrees, you'll (consistently) get 18 at the plug. Its a non-issue because you'll be tuning timing for power. If the number 28 in the cell in the timing table gives you the best power then so be it. You'll consistently get the same spark time.
    You're making a concern out of a non-issue.
    Dayton Ohio
    ok, that was much more clear. i guess i am too concerned with what the number that evoscan spits out, when i should just think of them as reference values. you can go higher or lower, it doesnt really matter what the actual number is, as long as i tune it for the best, safe, power output.
    thanks greg.
    p.s. i know the heads are interchangeable. i meant to refer to the CAS sensors, not the heads. my bad
    You can't mount the 2G cam sensor on 1G heads afaik.
    Greg, it is likely the timing latency is just another table somewhere, right?
    Dayton Ohio
    that is correct, chris. i WANT to use a 2G cam sensor, but there is no spot on the heads... and they are DR stage 3's, so i cant just go pick another set up lol
