Results 1 to 8 of 8
Thread: 10:1 TT AWD Virtual Dyno - Progression through tuning
    Never finishes any verified
    Wake Forest, NC
    For the past coupe years now I have been asked what the car has dyno'd. I always wanted to get it dyno'd but my biggest issue is that there are no close AWD dyno shops around me. So I was really glad to find out about Virtual Dyno and that it would function with MMCD.
    I spent the last couple of days trying to get it to function properly due to various issues. Brad the developer of the software has been a great asset. I reached out to him with my issues though email and he always got back to me within a day. with his help I tracked the issue down to be with how MMCD Tools was configured to spit out the csv file. Once I got it set up correctly I got my first Dyno graph.
    This pull is the first full throttle pull I have done in the car since the Emanage Blue upgrade from the SAFC2 I was running. The car was set at 8psi and AFR through WOT was 10.5-10.8. I tuned it rich for the first run to see how she responded. It was a good smooth pull.
    My idea with this thread is that as I tune and increase boost, to show the progression of the HP/TQ numbers using the Vitrual Dyno software.
    This is my base tune and starting point:
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    cool thanks for threading it!
    Canaan NH
    Should be interesting to see how repetitive the results are, thanks for sharing.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    wow 316whp @ 8 psi... I wanna know what it would have made on the 16 psi you had awhile back
    I don't bite
    Southern IN
    Try smoothing on 1. With AEM, any higher and it makes the graphs weird and "wavy." Also seems to show dips in power better with smoothing at 1.
    Wake Forest, NC
    Quote Originally Posted by Blackmount View Post
    Yeah I am really wondering also now. I most likely will not get back to the 16psi I was running though. I have a feeling I may peak at 13-14psi. Anything over that and the stock (b's won't hold to redline and the HP/torque will taper off. We will see.
    I left it at 3 as that seems to be the normal smoothing used. I'm logging with MMCD not AEM.
    Wake Forest, NC
    Just realized I was missing some info in this thread.
    Backstory: I have been unable to do anymore pulls/logs since the first one as the front end of the car has been breaking up pretty bad. At over 100 mph the front end was a mess and all over the place and very shaky I knew I needed a new halfshaft so I got one ordered from RockAuto.
    Well I got the half-shaft replaced and the new one is really beefy!
    I got the car aligned and I am still having some shaking in the front end. so need to get the tires balanced here in a couple weeks. Too busy the next two weekends to get it done. Probably going to just go ahead and do the ball joints also. They are original and could probably just use it anyways.
    Apr 2011
    Mid-April 2011.
    Monroe WI
    my VR4 has been a little squirrelly in bumpy turns so lemme know if you figure it out!
