No rush. I just like to see things implemented for their real use before I commit.
No problem, Ill take one tomorrow morning and post it up. Thanks for being patient
I'll take 2. Will paypal in the am
"I never knew I could drive like that. I was going faster than I've ever gone before, and yet, it all seemed to be happening in slow motion. I was seeing three and four moves ahead, weaving in and out of lanes like an Olympic skier on a gold medal run. I knew I was challenging the very laws of physics."
Ok, I should be able to ship them tomorrow as well.
Here are some pics of them on the engine. Given there is no timing belt or valve cover to set cams, the principal is the same. Get the timing cam sprockets set on the marks and simply install the lock as shown. The bolts with dowel pin off set will actually rotate and tighten in the sprocket lobes and holds itself to the sprocket. Then you tighten the wing nut and the sprockets can move because the lock is is transferring the tension to the other cam rendering it immobile, just like the plastic ones do.
Those pictures work for you FeaRpb ? If you need any other pics just let me know!
Yeah these pics work great. I will be picking up a set pretty soon.
Thank you
No problem, I should have these for a while.
TTT......got lots more of these
Got it, looks great. Will chime in once I use them!
