Results 1 to 8 of 8
Thread: two transmissions later...... same problem
    Jun 2012
    rochester hills michigan
    ok i bought this 92 vr4 a couple weeks ago, trans was pretty bad. all syncros were grinding second was completely gone and it would pop out of reverse. so i get it back home and pull it into the shop and pop the trans of and replace it with another one that was untested. it came off of a 92 tt stealth that was 100% stock and the car was in great shape minus damage from the fire. so i put that trans on an now it wont go into first or second gear so i pull that trans off an replace it with one that came off of a 93 vr4 that my buddy said went into first and second no problem. so i put this one in an same problem. i figure that the problem must be somewhere in the shift linkage or cables so i replace the entire linkage and cables and the bracket off the trans that holds the cables. still same problem i have no idea what else could be causing the trans not to go into gear any input would be greatly appreciated
    Feb 2011
    Scottsbluff, NE
    Sounds like your clutch is not disengaging when you press the pedal like it's supposed to be. Does the car try to move when you try to put it in gear?
    1995 Dodge Stealth R/T Turbo
  3. The Following 2 Users Say Thank You to DK77 For This Useful Post:
  4. #3
    Bleed clutch and adjust clutch pedal
  5. #4
    Jun 2011
    March 2008
    Upper Michigan
    Excellent advice regarding the clutch. Get a service manual and adjust the shift cables - you might be trying to engage two gears at once and the interlock might be preventing any shift lever movement.
  6. #5
    VR-3747 :D Not Verified
    Dayton Ohio
    there is a right and a wrong way to do it:
  7. #6
    Jun 2012
    I didn't get to work on it today. Have a few other stealths that need work. The weird thing is the car goes into 3rd 4th 5th and reverse. But te shifter feels like it's off. 3rd is where 1st should be 4th is where 2nd should be an so on. There nothing binding anywhere the radiator hoses and pre turbo pipes are not touching the 2 gear selectors off of the transmission any other ideas??
  8. #7
    Jun 2012
    i figured it out. it was a problem with the gear selector theres a square piece of plastic that goes into the shift fork that was out of place and wasnt allowing the fork to go down. moved it back into place, problem solved
  9. #8
    Dayton Ohio
    i know exactly what you are talking about too, i didnt even think about it!
