Page 1 of 110 1231151101 ... LastLast
Results 1 to 10 of 1099
Thread: The Otters tiny TD04 Build
    As some of you know I have been working on getting all the parts I need and what not for this so called build of mine. I have been posting everything about my build on my own forum and though I might as well make the info public. So for those who did not know.. The cat is out of the bag.
    So here is the small list of things I have.
    Built Pampena 3.1 6g72 w/ rays custom ross pistons with upgraded pins - oliver billet rods - new OEM forged crank
    Pampena 5 speed with 300m 25spline OS
    Clutchmasters 850 series (8.5'') Stage7/8 - 2 Lightweight Unsprung Race Disks
    Broomfield Racing Billet Transfercase
    Port and Polished Heads - Pinned - +1mm exhaust valves and GZP +1 and -3 degree cam gears
    GCTech Tubular td04 front & rear manifolds + rear o2 housing with Ceramic Coating
    Dynamic Racing DR-750r turbos
    STM tank to rail fuel kit
    HKS Twin Power
    Apexi S-ITC
    ABS Delete
    Austin@STM's Front hubs w/ ABS Sensor delete
    Austin@STM's Driver side intake manifold.
    Austin@STM's old stripped down VIS Carbon Fiber hood
    Austin@STM's Half size koyo race radiator
    Bought about $2400 in OEM parts to make this whole long block build fresh (Thanks Chris)
    DR ARC-2 w/ 92mm MAS
    BlackStealths LCD Boost Controller w/ MAC Valve
    Greddy SMI Boost/Water Temp/Oil Pressure Gauge w/ controller
    Deatschwerks Injectors 1000CC Injectors
    Walbro 400lph E85 Pump
    Treadstone TR1235 Intercooler w/ Custom Hard piping Thanks to Dave@Pampena
    Megan Coil Overs
    Corbeau Forza Sports
    Maximal Adjustable Control Arms
    STM Standard Oil Cooler
    Maximal Solid Mounts
    David's Replacement Trans Mount
    Ninja Performance IAC Block
    Pampena Billet Rear Diff Bushings
    TiAL Q BOV
    Pampena AWS Delete
    Austin@STM's VIS CF Hatch
    Solid Rear Diff Bushings
    Krank Vents
    Street/Strip Cage
    AX6 Front & Bobcat Rears w/ Power Slot Rotors - Brakes
    ACPT CFDS
    Aftermarket Radiator w/ pipes
    Very short exhaust
    Weds TC105N's
    Vibrant 6 port vacuum block (piece of shit out of the box)
    Torque Solution Solid Shiter Base Bushings
    STM Shifter Cable Bushings
    Greddy Magnetic Oil Drain Plug (so fancy)
    New OEM Oil Cap (just because)
    NRG Purple Lug Nuts (because rice)
    STM's Light Weight battery kit
    Fiberglass and Carbon/Kevlar Doors
    Carbon Fiber 99 Sail Panels
    Chromed ECU (99 Flash Ecu)
    Things I need:
    Get the car down to sub 3000lbs
    300m Rear Axles
    Convert Power Steering Rack to Manual Steering Rack
    Paint
    So I guess below I will post pics of the stuff I have and post info on how the build is going and the current state it is in.
    Here is the bottom end of the block
    Here is the DR-750's w/ the 16 psi forge wastegates (It's been too long but I am pretty sure its 16psi if not higher..)
    Here are the manifolds before and after coating.
    Here is the tranny at Ray's when he finished it
    Here is the T-Case when I got it back from him.
    Here is a picture of the clutch stolen from Austin@STM's facebook page.
  3. The Following User Says Thank You to FeaRpb For This Useful Post:
  4. #3
    Here are the Greddy Gauges in the dash.
    Here is my big box of OEM goodies from Chris.
    Here is the LCD Boost controller screen I put in my tach
  5. #4
    I thought I had more pics, but I guess not.
    Anyways, I am basically ready to slap the motor all together. I just received a package yesterday from Hans, which contains some exhaust studs for my heads (I replaced the nasty old looking ones) So once I put those in I will start putting the long block together.
    This should be a fun little project.
  6. #5
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    nice. what manifolds are those? did you coat them yourself or take it somewhere?
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  7. #6
    They are the GC Tech manifolds. I had Tirado Custom Coatings coat them, they are in Seguin, Texas. They do amazing work.
  8. #7
    Boston, MA
    oh. i'm a tard and completely missed that on your first post. looking to be a good build! take lots of pictures!
  9. #8
    Canaan NH
    Awesome, thanks for posting this.
  10. #9
    Tons of pictures will be had.
    And no problem CB, it was about time I do this :P
  11. #10
    looks like a nice build.
    How many months do it take for TCC to do your manifolds?
