I shipped the mani's to them on a Friday and they shipped them back on Monday.
And thanks!
And thanks!
wow, it took me about 2 months and threats of calling the cops. You sure are lucky.
Wow that's crazy, you are the only one I have heard of having a bad experience with them.
Post via Tapatalk
I'm assuming you'll be running E85 because the ARC-2 won't run 1000s on pump. It's too big. I've been running E70 on the DW1000s and ARC-2 without any issues. I have a Jester's Deadd flashable ecu ready to install though because I feel much safer having OEM fine control over everything considering I don't have a built motor. That and these 2nd gen pistons can go at any minute. How much boost do you plan to run? If you end up going past 30 psi I would recommend larger injectors maybe 1300cc which also means a different engine management. A hotwired Walbro 416 will be good up to then although I don't know how much further than 650AWHP it can be pushed without a BAP. I don't know your power goals but you have all the right parts to put down some serious numbers.
Oh yes, pictures of the car. I must get some of those haha.
You are correct, I will be running e85. Talking with Matt and Ray, none of them have mentioned to me about needing bigger injectors unless they overlooked that. I do plan on pushing these as far as they will go 35psi+. I plan on running either 1 or 2 Walbro E85 400LHP pumps depending on its needs at those levels.
My ultimate dream goal is to break 700, but we shall see.
Here are some pics after the engine was pulled. Once the engine build is done, I will tackle the engine bay and all its horridness.
Yeah ole girl needs some TLC before that engine drops. This is an ideal build IMO. You're running 5 speed right?
You got a hopeful completion date yet? Mine is April 1
1995 Dodge Stealth R/T Turbo
Steven has no intention of completion HAHA
