Welcome to the SL ECU/Chrome club, Schteben.![]()
Thank's KEV.
I am pretty excited to get to play around with it.
But also not excited with the amount of questions I will more than likely be asking haha. Luckily there is a ton of stuff already covered on the interwebs about it. So I have plenty of places to look.
Thought I would update this with the conversion harness I got together for the flash ecu.
The stockers rubbed just a little on the front..
Threw in a 5mm spacer, new wheels and tires fit perfectly.
Hooked up the ecu, put on ecuflash, looks like it is reading. Just need to figure out what I need to do settings wise to the LCD boost controller to get it to read from this ecu.
Now to read a bunch and figure out what I need to do to get the DW1000's set up in the Chrome ECU and then flash it over.
I love the light gold wheels on your black beast! Also, jelly of the chrome. What MAF will you use with it?
I am using the 90mm GM Maf that came with the DR-ARC2 that is also on the car. I am really only using the chrome for injector scaling and i will toy around with launch control
Just ordered a new IAC from rockauto as I know my previous one is dead. Going to see how well that helps my holding idle issue.
But other than that, I have been just messing around with the Chrome ecu and injector scaling stuff. I zeroed out the DR-ARC2 to what it should be set to on first start up (0 / -7 / 0 / +2) Doesn't start good without giving it throttle and holding it.
Going to wire in the wideband into the ecu so I can pull some logs.
Hope to get it all running good before Feb 13th
