Results 11 to 20 of 23
Thread: JDM vs US tranny differences?
    Medford OR
    And ONLY if a 6 Speed. Did the OP specify 6 speed and I just missed it?
    I'm still missing it.... What year car are we talking about?
    Nov 2012
    good old Lancaster, PA (also known as the Amish Town)
    sorry it's a 6sp i'm asking about.
    Twin Turbo verified
    Melbourne, Australia
    As stated above transfer case is the same. Rear differential ratio is the same as the 5 speed so change tail shaft and diff is easier than opening the box to change front diff. That will also most likely void any warranty you have on it.
    Sent from my GT-I9300 using Tapatalk 2
    Waiting install
    Build Thread
    We can help you out. Just give us a call at 610-438-0439
    Thanks CoreyB
    you don't have to change the "driveshaft", just the rear end.
    Nov 2012
    ok thanks guys, lastly how would you know for sure that your transmission is bad, and how would you know if your transfer case is bad as well. My transmission grinds 2nd and 4th when shifting at about 3k rpm and above and when down shift into 2nd, so is it for sure that it is bad?
    By the way, i haven't purchased anything yet. I'm asking this so i would know which route to take and which route would be more cost effective. Thanks again
    Oct 2011
    Sundsvall, Sweden
    Sounds like all you need is new syncros, get some quotes from reputable 3S shops that work on these gearboxes (Ninja, GZP, 3SX, Jacks, Kormex etc).
  8. #18
    Twin Turbo verified
    I was of the understanding that you need to change the last half of the tail shaft/drive shaft. Obviously he would need a jdm diff or a 5 speed one.
  9. #19
    The difference in the driveshafts is only like 3/4". You can use either in either in a pinch and even on a 13t car launching hard no issues were had, other drivetrain parts break before you can strip out the yoke.
    BTW, it's the front section that's different.
  10. #20
    That is not true. The mounting flange and everything else about the rear 2 sections of the shaft is the same. I'm running a 6 speed rear section in my 5 speed car right now.
