Results 1 to 10 of 20
Thread: I have a problem...need help
    Tokio Krisis Not Verified
    Nov 2012
    Oct 2012
    Let me start with my car:
    1997 3000gt base
    155000 miles (120k tune up done)
    nothing special
    short ram intake (recently changed due to rubber 90 degree elbow damaged)
    I'm driving to work today (doing the speed limit) when i notice my tach is jumping from 0 to 3500 in 5th gear. Put in neutral and it stabilizes between 800 and 1000 rpm. Put back into 4th and continue driving. shortly after my tach starts acting up again, only this my car shuts off. Power from the battery takes over and i am able to start my car while coasting. I pull over into an Auto Zone when it died again when i came to park. I do a visual check for anything obvious in the engine compartment. NO NOTED DISCREPANCIES. I run inside to get the codes checked and nothing came up. I pull out of Auto Zone to continue to work, not long after i feel my car bogging down and tach gauge again jumping. I apply alittle throttle and it continues to run. I notice it mainly does it when my foot is of the gas and im coasting along. There is no flucuations in power. I'm going to take apart my intake this weekend to see if anything is out of the norm. If you guys know of anything that could be the issue please let me know. Thanks.
    Tokio Krisis
    Ecu?..
    Sounds like the cam or crank sensor. The later SOHC's have a crank sensor mounted behind the crank timing gear. I think the cam sensor is inside the distributor. Could be ignition control module.
    Nov 2012
    Oct 2012
    ECU....okay. ill have to look at it. I think its near my stereo right?
    I doubt it's your ECU. Sounds ignition related.
  6. The Following User Says Thank You to stealthee For This Useful Post:
  7. #6
    Nov 2012
    Oct 2012
    Crank sensor, cam sensor, and ignition control. Starting to sound like my intake system may not be my problem.
  8. #7
    Nov 2012
    Oct 2012
    Any tips on isolating it down...like which is mostly likely or has been the common failing component?
  9. #8
    Intake won't make your car surge like that unless you have a massive vacuum leak. Even then, it would idle high. Only intake possibility is the MAS. Check to make sure it is securely attached and not leaking. Also make sure it is plugged in tight.
  10. The Following User Says Thank You to stealthee For This Useful Post:
  11. #9
    Super Asurada SA-01
    Oct 2012
    Silver Spring, MD
    I had this exact problem when I had my 97 SOHC years ago. My tach needles would act up then the car would shut off. It would randomly throw CEL but the light always went out by itself. Had a few close calls when the car shut off while I was turning at an intersection. After trying to troubleshoot the problem for weeks I gave up and went to my mechanic. I don't exactly remember what it was but it was a frayed ECU wire randomly coming into contact with a metal part nearby. Sorry I can't be more specific, but definitely start by looking for frayed wires or loose connections.
  12. The Following User Says Thank You to Prime12 For This Useful Post:
  13. #10
    Nov 2012
    Oct 2012
    Hey guys, I was able to fix the problem. It was the ECU. The capacitors were leaking. I replaced them this morning and been driving all day. It hasn't done anything wrong so far. The tach did not jump around at all. Thanks for all the help guys. Ill definitely keep coming back here for more advice.
