Results 1 to 10 of 13
Thread: Whats the clutch of choice these days for a bpu++?
    West MI
    This is for a friends car with 16t's and supporting, most likely will never see a track and he is running an 18 spline so a little bit of slip is not a bad thing.
    Last I heard people were avoiding the sprung hubs, so I was thinking a Spec stage 2+ unsprung? I will not buy another SB unless its a stage 5+ modified like I run so dont bother mentioning that.
    Maybe an rps pp and stock disk, who sells just the pp these days?
    Thanks, I just really hate shopping for clutches with my luck, and I will feel terrible if this clutch doesnt last for him.
    San Francisco
    When I got my first RPS pp I got just the pressure plate and used an OEM disc ... I forget who it was but that means someone, somewhere sells em separate. I think that'd be a solid choice, I've only ever ran RPS max pressure plates with oem discs and it's always held everything I've thrown at it.
    Kentucky
    I like my new SB stage 2 clutch with the IPS lightweight flywheel
    Fowlerville, MI
    Quote Originally Posted by SpdDmnVR4 View Post
    Just don't keep up the clutch too much or you'll have a clutch swap in a parking lot on your hands :whistles:
    Stock clutch will hold pretty good, if he doesnt plan to launch the car, and it will be very nice to drive that way. Otherwise a mild PP will hold a decent launch and hold a bit more power as well.
    And the list goes on...
    2006 - 94 Base model ; 2008 - 94 VR-4
    San Diego, California, United States
    IMO, I'm running a BPU @ 15psi on 9b's and I use an Exedy OEM replacement clutch w/ an OEM flywheel. Well over 20 pulls and almost 2 years later it's still holdin strong.
    Quote Originally Posted by Atrosity
    Quote Originally Posted by CandyAppleVr4
    3S's have been turning normal people into mechanics since 1991. =P
    yeah you can say that again
    ACT MB019 pressure plate and stock disc holding great for me:
    http://www.amazon.com/ACT-Technology...5697535&sr=8-1
    Light pedal feel and excellent streetability. Ordinary people wouldn't realize it wasn't a stock clutch.
    The RPS plate is great too, but about $100 more.
    -BOOSTTD- verified
    Elko, Nevada, United States
    The stock clutch disc is holding up to 19t power for you? Wow, I guess I didn't realize how much a pressure plate does for holding power. I've got an ACT, Centerforce, and a Southbend pressure plate sitting at home, but I always figured I'd need a good performance clutch to be able to hold the extra power I'm running. A stock disc at probably $70 sounds A LOT better than $500 for a spec 2+
    sure, the RPS plate rated at 580 torque uses the stock disc. The act is rated at 500. RPS or ACT may take a bit of the marcel out to make it engage a little quicker, but the material is stock.
    The act and RPS plates are around 30% more clamp load (the mb019, there is another Act plate that is less), so they support 30% more torque. The stock clutch is actually pretty good, so add 30% to what it can hold and you have a decent clutch.
    Certainly if you aren't going to routinely launch then a stock disc based clutch is best for streetability and longevity.
    If you drive like a fiend then a 6 puck or spec stage 4+ type disc with no center springs is the way to go.
    -BOOSTTD- verified
    Hmm so I'd be alright to use a stock clutch with any of my pressure plates and hold 15g power all day long? Even with launches and spirited driving? I was under the impression that the stock disc was no good after about 400hp at the crank. The upgraded pressure plates must make an appreciable difference then.
