Results 1 to 8 of 8
Thread: Fuel Pump Assembly
    Fuel Pump Assembly
    I am installing my IPS fuel hat with a walbro 255. I ran into a snag and need to know if these parts are different from a NA than a TT. Its the rubber piece and the metal bracket that hold the pump in place. As you can see the pump is not even close to fitting correctly, it seems that the rubber piece is not thick enough and the bracket is not long enough causing it to be angled and not completely seated in housing inlet. If that's not the case it seems I need the walbro with the inlet and outlet on the same side.
    -Josh
    Banned J. Fast's Avatar
    Quote Originally Posted by Beef6 View Post
    -Josh
    Buy a couple stainless worm clamps and clamp the fuel pump to the upright. For insurance you can secure the clamp with nut, washer, and bolt to the downrod.
    The non turbo rubber piece is thicker than the TT
    Hmm and that's what I have and its still not thick enough. What about the metal bracket, does the TT one extend further out?
    Well I got it to fit.
    I flattened the bottom bracket (not completely flat to make up for the height different in the pump) and drilled a new hole so it fits pretty well now.
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    you could also just use zip ties to secure the pump to the hangar. works great on mine.
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
    Quote Originally Posted by sketch View Post
    I was concerned about the pump not sealing correctly due to the angle the pump would be at in order to zip tie it to the hanger. Probably wouldn't have affected anything but when it comes to fuel I'm always paranoid.
    Corunna, IN
    Looks good to me!
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
