Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: White R/t body panels, some interior, some N/a
    St.Louis
    Well I gutted a Wrecked 91 TT with 116k on the clock for the AWD swap and ive got a lot of parts left over and some from my N/a. All prices are excluding shipping and are obo. Post here or text me at 636-399-7289 any time to get ahold of me.
    The trans / engine / rear subframe i am keeping for my car and everything else is up for grabs.
    Parts list:
    TT knuckles-bare-50 shipped
    FWD Addco rear sway bar-Sold
    blown 18 spline VCU-$20
    18 spline output shaft -$70-sold
    First gen AC bracket-$10
    Power steering pump (v belt)-$15
    Ac control box-$30
    Digitial AC control motors set of 3-$45
    First gen rear calipers with lines-$40-trashed
    91-92 3SX light weight crank pulley-sold
    Ac core (interior)- $30
    Rear bumper-$110-sold
    Side skirts $45 ea-donated
    Door caps $30 ea
    Tail lights $50 for the set-donated
    1G Rear center garnish for a 3000gt $30
    Stealth rear garnish strip - donated
    R/T sails -Sold
    FWD rear toe arms w/ Teflon coated endlinks-$100 (less than 30k on them)
    93 FWD 5 speed with 10% taller 5th gear-$375 grinds going into 2nd/3rd ive been rev matching so some new synchros should do the trick. Will sell 5th gear separate for $125.
    FWD trans end cap - $30
    FWD Trans bell housing - $60
    FWD Trans Mid case - $45
    FWD Diff (needs bearings) $15
    FWD Shift forks + rails- $10 Ea
    1G Stealth air bag $25
    91 SRS unit $20
    2 first gen TT ABS units $30 ea
    Rear ABS sensors (AWD) $30 for both
    Drivers side engine splash guard $5
    FWD fuel sender unit with pump $30
    1G stealth Fog light set $35 ( one is chipped in the corner)
    1G stealth turns/ bananas-$70 great condition -sold
    Set of 4 new OEM AWD sub frame bushings-Sold
    MFI relay $30
    PTU $35
    Non-gutted precats- Will trade for gutted ones + cash?
    Stock 9b's With 118k on them, will need to be rebuilt- Offer
    Rear steering rack and pump, no leaks,minor surface rust, no torn boots $60
    I have a lot of other interior parts that are in my attic and tons of miscellaneous electronics/ relays available so feel free to ask about things not posted on here as this is what i can think of off the top of my head. Pics will be up soon of some pars.
    St.Louis
    St.Louis
    bump for the day. remember everything is obo!
    gawd i wish i needed something. good luck!
    St.Louis
    Also have a set of 4 new rear sub frame bushings for a AWD sub frame. $45obo Bump
    St.Louis
    bump for the day!
    St.Louis
    bumpity
    pics of the fog lights?
    Hopewell Junction, NY
    color code on the fire wall?
    i know its white but what does the tag say if correct code interested in both front fenders if clean
    Kx
    St.Louis
    Quote Originally Posted by Kx1984 View Post
    Kx
    Front fenders are gone, sold em to a local a few weeks ago. I will look up the color code when i get home for future reference. The entire frame of the car is gone as I gutted it then sold the steel as scrap (after cutting out the AWD stuff)
