Results 1 to 10 of 11
Thread: ASA Part # Thread
    ASA Part # Thread
    Post up ASA part numbers for OEM parts
    2G VR4 rear brake caliper anti-rattle spring (cross shaped spring): MB950668
    See above to install ASA for yourself.
    Super Asurada SA-01
    Oct 2012
    Silver Spring, MD
    MB605467 Oil Cooler Core
    MB605470 Oil Cooler Oil Return Line (what most people refer to as 'oil cooler lines')
    MB605475 Oil Cooler Oil Return Line (hard line that sits on top of the cooler core)
    MB605468 Oil Cooler Oil Feed Line (another hard line)
    MB033054 Crush Washers
    MB033025 Banjo Bolts
    Never finishes any verified
    Wake Forest, NC
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    TT complete gasket Kit MD997670
    Timing belt MD193874
    tensioner adjuster MD319040
    tensioner pulley MD140071
    water pump MD972005
    idler pulley MD319022
    crank pulley 92-99 MD177199
    oil pump 93-99 MD190982
    thermostat + gasket 92-99 1305A237
    16 cylinder head bolts MD065959
    knock sensor MD159216
    o2 sensor Front O2 MD164422
    Rear O2 MD164423
    Pulley AC/Alt Lower Tensioner MR360357
    Pulley AC/Alt Upper Idler 91-99 DOHC MD318474
    4 alignment dowel pins heads MS471112
    oil feed+return lines Oil Feed Front MD161898
    Oil Feed Rear MD174793
    Oil Return Front MD160039
    Oil Return Rear MR266015
    turbo water lines Coolant Front Feed MD194061
    Coolant Front Return MD153689
    Coolant Rear Feed MD158758
    Coolant Rear Return MD153691
    Coolant Hose feed-left (rear turbo) MD168962
    Coolant Hose feed-right (front turbo) MD122589
    Coolant Hose return-left (rear turbo) MD153693
    Coolant Hose return-right (front turbo) MD081048
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    Great add for those that can install ASA. Adding to OP
    Maybe some day I will rebuild the ASA VM and rehost it.
    Wake Forest, NC
    I also have a price list that someone created that you can import into ASA so it shows a price. The prices are a little outdated but most are within just a couple dollars of what the actual part costs. I'll have to track it down and add it here also. A 3s member cerated it so they might chime in with it.
    TN
    It was NickS VR4, but I don't know if he ever posted it over here.
    Found it: http://www.3sgto.org/f2/mitsubishi-a...list-5884.html
    Wake Forest, NC
    Perfect, Thanks April.
    You do realize that you posted a thread to this site, So yes he did post it over here...LOL
    Mirror link incase Nicks link goes down:
    Mitsubishi ASA Price List
