Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: just joined and I have few questions.
    Fosho. Can you send me the address. Ima work on the pressure test on sat so I'm ready for Sunday.
    Sweeeet.... can you send me the address? Ima be doing the pressure test this sat so im rdy for sunday.
    Nov 2011
    Menifee, CA
    Quote Originally Posted by rollingoose View Post
    Did you join the socal site? Look up under gatherings. I'll send u a pm with the forum link..
    Sent from my SPH-L710 using Tapatalk 2
    yes i did. got the info already, got the parts to work on my vr4 tomorrow ill let you know how it goes. thanks alot man i cant wait till i see some nice vr4s.
    ok finally done with the pressure test found out that there was insanely leak on the oil cap and a little red house that goes
    on top of the throttle body to a letter P was ripped. fixed both of them went for a drive and power is back, but there is still some jerking
    between 2.5k to 3k rpm with a sound in the engine, sounds like when you hit an empty 5 gallon barrel its more noticeable when you try to floor it on 3 gear. car started a 1.5k rpm on cold
    and it stays at 500/600 when worm.
    How many 5gal barrels have you hit? lol
    Have you checked your ECU yet? It sounds like the car is backfiring.
  7. The Following User Says Thank You to green-lantern For This Useful Post:
  8. #17
    RTBOOST verified
    Florence, Wisconsin
    Have you checked the plugs and wiring yet? I'd also replace the fuel filter while you're at it so you know that you should be getting enough fuel along with a strong spark at each cylinder...And remember, OEM parts will save you some headaches over most of the cheap China crap that's often sold at the local parts stores.
    BTW: I'm suggesting these things 'cause I was getting a stutter/hesitation around the same RPM range as you & it turned out to be the fuel filter (which was installed backwards)...it cleared up after I put an OEM one back on & in the correct way.
    GL man!! Keep us posted with what progress you're able to make on getting this car back into shape again.
    Sent from the garage
  9. The Following 3 Users Say Thank You to Street_Chally73 For This Useful Post:
  10. #18
    yeah thats what thought at first that it was misfiring so before the pressure test that i did today i had done full wiring with new Laser Irirdium Spark Plug, fuel filter, tryed my brothers mafs on my car, new tps, few fuel system additives, all OEM parts(dont wanna put trash on my baby haha) but still a problem and thats when i searched for help. but backfiring is still in the list.
    ima be checking the ECU tomorrow, i was reading that it could be the PTU, i wanna try and figure it myself before i go to a shop. as i wanna learn more about my car im no mechanic but a can take something apart and put it back together.
    i didnt trust any of the shops around but i found some legit places in socal3s.com (thanks to stealthknight619) in case i have to take it. thanks for answering and help
    oh shit just found this vid http://www.youtube.com/watch?v=YSsiHllccyI and my car is doing the same thing.
  11. #19
    ok pulled out the ECU everything looks good on it. here are some pictures. still wanna have checked out tho as i said im having the same exact problem as the brother on the vid and said that "Ended up being a tiny transistor in the ecuit was a tiny" and had it checked on two different shops. you guys have a legit shop that can send it too?
  12. #20
    Ok finally got to take my car to a real vr4 mechanic his name is chai in reseda CA what a great guy. And he said the timing belt had jumped 1 teeth. Since my car has 132k milles and dont know if last owner did it I decided to do the 120k service.
