I changed the thermostat in a VW...
Good grief, even the alternator is buried...
...im guessing front end removal is required for dam near everything?!?
good lord, what is it?
Haha, the newer VW's can be a massive PITA. On my New Beetle, everything was hell to get to. Changing the battery? Changing a headlight? Alternator? Better block off a weekend, lol. No complaints about longevity though, I beat the piss out of that car and it was still going at 260k+ miles, original clutch, 1st and only plug/wire/timing belt change at 160k. Never changed the oil, just ran it dry and added more to it every year or so, LOL.
04 Passat
You got very lucky... You should play the lottery.
Can't count the water pump impellers that have fallen off at less than 100K... Many as soon as 50-60K. Completely sludged engines with plugged oil pick-ups from poor maintenance, numerous codes stemming from rotted vacuum lines on a 5 year old car, oil leaks, and just about every one I see has a coolant leaking out of the plastic water outlet...
