Current:
2004 ML500 - Mommy Mobile
1995 3000GT VR-4 - lawn gnome
1999 3000GT SL - 7,436 miles
FOR SALE:
Ah, strange that the front turbo seized. How hard did you try to spin it? Was it basically welded in place or was it just tough to spin? I'm almost sad that you put a '99 front on it because your car looks perfect as-is to me... But I know how that goes. I struggle with the '99 temptation regularly.
Any tricks to installing those head studs? They're going on my pampena block when it arrives (no rush, Ray).
HAHA... I love it. If the pump can take it (which it obviously can), who cares.
Well I simply just want to get my car back running again. I tell ya, after spending ass load of money & 23 months at this shop for which that seem like enough time to make sure everything is running with no problems. So, I pick her, drove her home which is 230 miles from this shop. Park her in the garage. Got Sunday morning, left. Came back that Sat, installed new radio. Drove her to put some air in the tire. Drove her back home. Parked back in the garage. Four days, later tore my achilles. As my pops to swing by the house to crank her, he ask me if I put E85 in her, I said yes Did it b4 I left. He calls back tells the fuel lights on, I tell him a have extra jug of Corn juice. He puts it in. Attempts to crank the car, nada. He's buddy ask if he could see were all my money went. Pops the hood. Told my Pops to shut off the car because the Corn Fuel is spraying all over the place. So, I contact the shop, told him whatup. Now I havent had the car back for less than 2 weeks. Told them what happen. I was told see if I can't remove the fuel line, for which I was like I PAID YOU GUYS to have this stuff done right. Since them a video of what was happen. Ask to speak to the Owner, Owner told him he couldnt afford to send a tech out. Ask if i knew anyone that could take off the line and return to them, I was like no. Plus I'm out of work with a tore achilles. Owner was like if i can get someone to remove he's pay them. I'm like dude, there's no one close that knows anything about the car. Granted I spent tons of loot with them and to her the B/S excuse he gave me, well I lost all respect. I'm mean, if I had a product that was put on by my tech at my shop and I get a call from what I would consider a loyal customer. That's a few hrs away in the same state. Well I'll do what i have to do to get that customer car fix. So, Now i have a car this being sitting since Nov 9, that I can't crank nor drive. Thanks to the wonderful craftsmemship of this Company. So, ALL I hope is to get her back running and not have to keep spending money on stuff that should work. I'll be alot happier. Sorry guys for venting but this sh*t bn on my mind since Nov. I just want to see how 700 plus awhp feels that's all.![]()
More Videos...
One year I'll make it.
Was hard to spin at first but once removed and some PB Blaster got it there it free'd right up. But still had to send them out to have a looksee and of coarse they found evidence of oil starvation. Which reminds me I'm going to re-do my oil cooler as it has the fittings on the side of it and not the top like oem. Think it was draining when shut off and taking too long to refill. I think the '99 front end look so freak'in awesome especially with the CF Victory hood I have. Now the hood and headlights just seem to flow. That and I need more airflow in the summer sitting in traffic with the AC on.
Head studs took some time as you had to torque them then loosen them as per the instructions, but for the most part was easy. Hard thing that I did was degree'ng the cams. Found out my Fidenza cam gears were off a little. Not sure if they were off or it's a result or combo of the heads being milled or the DR (Web) Street cams but now have "true" zero.
Ya I got my work cut out getting the car back in there. But I'm working on it. Hard part is figuring out where all the shit goes back in the engine bay. And of coarse you can't put the old hardware back in.
"Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did.w/DBB DR1000's
^^wow the car looks phenomenal, exceptionally clean. Great work as always.![]()
I don't follow your theory on the oil cooler. It is thermostatically controlled, bypassed when cold.
I thought you were running inline oil feed filters that matt recommended removing?
I had the oil cooler lines off after the engine had been off for weeks and tons of oil came out when I unhooked the line from the filter housing. My ips cooler is side mounted like yours. The filter seems to prevent backflow.
If you can do without your VR-4 for a few weeks since most of us all have other backup cars for our dd if it's a 3S, sell your ECU, MAFT and GM MAF, and SAFC. You could keep the MAFT and GM MAF if you really wanted but it would be interesting to see how far you could push the EVO 8/9 MAF sensor. I'm sure you have extra parts laying around the garage or inside the house. Hell, even non-car related stuff in the house you don't use anymore. Sell it off to get some funds for the VR-4. That's what I do now to mod my car is sell off parts I have so it's not coming out of my paycheck.
It is pretty cool being able to run most of the factory fuel system on E85. My 1000cc injectors are almost maxed out at 30 psi of boost and the Walbro 416 isn't too far behind without adding a BAP I have to get another adjustment knob for if I want to use down the road. Other than a 3SX fuel rail loop my fuel filter, rails, lines, etc are all stock. We definitely underestimated the flow capacity of the stock lines. I have no issues with overrun either. It's all tuned out. I actually run lean 16s AFR at idle due to not having fine enough control with the ARC-2 but the car runs great outside of occasional vacuum/boost leaks rearing its head after some high boost 10-140 pulls. I will probably see how much further I can go on the stock fuel system with a BAP. I would try dual pumps out of curiosity if I had all the adapters and fittings but I'll go dual feed when that time comes.
