Started cleaning out the garage so I can get my car back in there so I can start putting her back together. Miss cruising with you guys.
DR DBB Billet DR1000's
Treadstone 4 1/2" FMIC
PNP Plenum with either the CXRacing TB or soem other billet one that doesn't leak.
Still undecided which route to take as far as tuning goes as I have 3 options to go with.
Keep it the same with the Pro-M and SAFC with Water/Methanol
Put in the new Flash "Chrome" ECU I picked up
One of the above to get me an inspection and then swap it out for the AEM Ver 2 running E85
Ray..you're on E85 now, What injectors and pumps you running on your car Ray?
"Life should NOT be a journey to the grave with the intention of arriving in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out and screaming "WOO HOO what a ride!"
----------------[2007 Ride of the Year.................................. 3.5 Stroker I did.w/DBB DR1000's
-- Timing belt and covers. Then get the motor back in the car, build the adapters for the accessories (6g74 so need a plate adapter for items that bolt to the head and the block) Do some re-wiring install the twin pump kit in the fuel tank. Decide on a fuel line setup, get the driver side intake adjusted as it won't currently clear the timing gears, build new intercooler piping from the intercooler to the throttle body (Decide on which throttle body- have 3 now), get the turbo rebuilt. The turbo still looks good and no shaft play but since the last motor grenaded I don't trust the bearings to not have metal in them. Install the AEM-EMS and hope she starts. This is the 6g74 block Ray sold me ... 3 years ago? Or longer. It looks pretty on the stand, but I do miss driving the GT.
In short .. a lot and no time whatsoever to do it. Wish Ray's shop was closer
Eric C.
I'll be doing an engine rebuild + any other routine maintenance that was neglected over the years.
Pulling the engine and diagnosing it. I may end up getting a Pampena shorty depending on what I find.
While taking the pipes of last winter to polish I discovered my front turbo shaft was seized. Go figure right, was fine was she was put away for the winter. Removed them both with engine still in the car which was a roya PITA and sent them to Matt to get rebuild. Ended up getting them done using his new Billet wheels. Once i got them back I figured it would be easier to remove the motor to put the turbo's back on so the car had to sit outside as I got a small ass garage barely big enough for just the car, of which it did at least have the cover on. And then it sat as I got lazy. Then come last spring I started working on her but always wanted to get the engine bay painted so since the motor was out now was the time to do it. So off it went to my auto body guy to get that done and also did a '99 front end with half the car repainted. Looks awesome. While the motor was out I also cleaned her up, installed Itallto's head studs and few other small items. Then got lazy again as I got side tracked having a in-ground pool in.
No I'm determined more than ever to get her going again this spring as it's been way too long.
