Results 11 to 20 of 31
Thread: ecuflash problems
    Quote Originally Posted by Kx1984 View Post
    I just had to place the files back in the correct folders
    But any Roms I saved/created were deleted :/
    Which was y I said save them in a different folder
    Can I get a screen shot of your ecuflash options settings please?
    228 scanning for metadata models in C:/EcuPrograms/EcuFlash/rommetadata
    You need to make sure the XML (23862006.XML) from the chrome instructions is stored in a sub folder of the above directory. I'm guessing its different since you chose to install ecu flash here instead of program files directory.
    I did I made a folder called 3000gt and put 23862006.xml in it closed everything out, then opened ecuflash and tried to open the 23862006.bin and I get the error unknown rom image. Is there and way to test my xml out. All I have to do is flash my car to get it back running any help is much appreciated
    Ok I tried a evo bin and it worked perfect so there has to be something wrong with the xml right
    I would try to move the XML file from where you currently have it to some other folder outside of the rommetadata folder and restart ecu flash to see if the models read stay at 612 or reduce to 611. If the number stays at 612, ecu flash is not reading your XML. If it reduces, there might be something going on with version 1.44. I'm using version 1.42 right now so can't help there.
    Cool I tried that and it did go to 611 so it is reading the xml. I might try to get 1.42 and see what happens but before that can I post it the xml for Greg to check out to make sure nothing is wrong.
    Ok i tried 1.42 same thing. I swear it's the xml. I dont know how but its messed up.
    I lack color... verified
    Aug 1998
    Quote Originally Posted by fridayda13th View Post
    Well I deleted my old ecuflash and downloaded the 1.44. Now I can't read from the ecu or open the v2 rom. It just says "unknown rom image". I did install the xml. to the correct folder to. What should I do?
    This is what the definition is:
    <rom>
    <romid>
    <xmlid>23862006</xmlid>
    <internalidaddress>1021a</internalidaddress>
    <internalidhex>23862006</internalidhex>
    <caseid>?</caseid>
    <make>Mitsubishi</make>
    <market>USDM</market>
    <model>3000GT</model>
    <submodel>VR4</submodel>
    <transmission>Manual</transmission>
    <year>1999</year>
    <flashmethod>mitsukernel</flashmethod>
    <memmodel>H8539f</memmodel>
    </romid>
    No need to post the XML. This is correct.
  8. #18
    Aug 1998
    Guess I'm not understanding why you deleted ECUFlash. It upgraded and reinstalls itself...
    I would re-send you the XML but my laptop died. Going to be a while before I'm back up and running.
  9. #19
    Cool is there anyone else that could send it to me
  10. #20
    Aug 1998
    What's your email?
