Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: ecuflash problems
    ecuflash problems
    Well I deleted my old ecuflash and downloaded the 1.44. Now I can't read from the ecu or open the v2 rom. It just says "unknown rom image". I did install the xml. to the correct folder to. What should I do?
    This is what the definition is:
    <rom>
    <romid>
    <xmlid>23862006</xmlid>
    <internalidaddress>1021a</internalidaddress>
    <internalidhex>23862006</internalidhex>
    <caseid>?</caseid>
    <make>Mitsubishi</make>
    <market>USDM</market>
    <model>3000GT</model>
    <submodel>VR4</submodel>
    <transmission>Manual</transmission>
    <year>1999</year>
    <flashmethod>mitsukernel</flashmethod>
    <memmodel>H8539f</memmodel>
    </romid>
    Keeping it real...
    Oct. 2006
    Reno, NV
    Brick?
    Ps I'm in town just for a few minutes.
    Not this time I just got it back from Brett I tried to read the ecu and nothing, It's not even connected to the car and I can't open the v2 bin. Ill pm you my number if you want to meet up and see whats wrong with my computer or ecuflash.
    Hopewell Junction, NY
    u updated the ecu flash program?
    if so u need to re install the files
    i had that same issue
    save your roms in a different folder prior to updating ecu flash
    kx
    Ok ill try that, Im going to delete the ecuflash and start over again.
    Quote Originally Posted by Kx1984 View Post
    kx
    Can you explain more before I download ecuflash again, I have 1 rom for ecu flash, 1 for evoscan and a bin file the one I couldn't open.
    I lack color... verified
    Aug 1998
    You have to make sure ECUFlash is pointed to the correct folder with all the XMLs. It's in the options settings. I'd take a screen shot but my laptop died.
    Quote Originally Posted by fridayda13th View Post
    I just had to place the files back in the correct folders
    But any Roms I saved/created were deleted :/
    Which was y I said save them in a different folder
    Ok I went to ecuflash, options, rom file directory. I changed that to the rommetadata folder and still get the same message. Could there be something wrong with my v2 bin?
    Does this look right:
    217 EcuFlash Version 1.44.3721
    217 OS Version Windows 7
    217 Qt Version 4.8.0
    228 63 memory models read.
    228 scanning for metadata models in C:/EcuPrograms/EcuFlash/rommetadata
    895 612 ROM metadata models scanned.
    895 checksum module "subarudbw" loaded.
    896 checksum module "mitsucan" loaded.
    896 checksum module "mitsuh8" loaded.
    896 patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
    patch module "Mitsu CAN RAM Parameter Logging" loaded.
    898 *flashing tool "wrx02" loaded.
    900 *flashing tool "wrx04" loaded.
    902 *flashing tool "sti04" loaded
    903 *flashing tool "sti05" loaded.
    904 *flashing tool "mitsukernel" loaded.
    904 *flashing tool "mitsukernelocp" loaded.
    904 *flashing tool "mitsubootloader" loaded.
    904 *flashing tool "shbootmode" loaded.
    906 *flashing tool "shaudmode" loaded.
    908 *flashing tool "subarucan" loaded.
    910 *flashing tool "subarucand" loaded.
    .911 *flashing tool "mitsucan" loaded.
    The next guess I have is the v2 bin file may be messed up, But only Greg would know that.
