Results 1 to 7 of 7
Thread: 92 stealth rt non turno
    Does anyone no where I could buy a single turbo setup I got the full t3 t4 kit today I need a single turbo manifold or can I use the twin manifolds and run two pipes from the turbo and use a y pipe I will have to Fab a manifold it looks like I seen single set ups and they put the turbo by the pass anger shock tower
    Let me just say this:
    V6's, by nature, are better suited to twin-turbo setups; I6's, by nature, are better suited to single-turbo setups.
    I'm Kind Of A Big Deal
    Quote Originally Posted by STEALTH R/T View Post
    It is much more cost effective to get a twin turbo set up. But we all told you this already. You will have no traction as a fwd, and your engine will not hold any reasonable power at the 10:1 compression. Sell your car, and buy an rt twin turbo, as that is what you seem to want to make your car into.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Isn't that a bit big for 10:1 anyway? I couldn't run much more than 8-9psi on 9b's 10:1 without getting knock.
    Rochester Hills, Mi
    Well guys, we tried to warn him. We can always say "told you so" later..
    As far as getting single turbo parts, I don't know of any off the shelf setups. Every one I have seen has been custom plumbed EVERYTHING by people who are not new to the game.
    Good luck.
    95 Base 3k: 6G74/TT/AWD conversion
    Feb 2012
    Aberdeen Scotland
    IPS used to do a single turbo manifold setup. You can make a collector from to standard manifolds and bring them together. Yeh there's pro's and cons to different setups, if it's a standard engine, you might be better with a couple 9b's off a TT. If you like welding and something different then single's the way to go..
    cheers,
    Ewan
    Jack Stand Driver
    Jan 2013
    Central TX
    Its like they said, the money and the headache spent to convert an N/A to forced induction in a RELIABLE way is A LOT more than buying a stock VR4/TT. Also, just like IPD said, V motors are better suited for twins. It will be a better balanced system to run a turbo off each bank rather than two exhaust banks spooling up a single turbo.
    1991 Dodge Stealth R/T (RIP)
    1992 Mitsu 3000GT SL (sold)
    1991 Dodge Stealth R/T TT
