Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: another no start thread
  1. #61
    Jan 2011
    az
    Is this the correct way to put the cas in with the motor and cams at tdc ??
  2. #62
    Stealth owner since '91
    Sthrn NH/Eastern Ma
    That looks right to me. Anyone else have any thoughts?
    (Sigh) (With 657 views I was really hoping someone else would jump in.)
    You said that you and your Dad just put this back together? What's the back story? What did you guys do?
  3. #63
    Jan 2011
    az
    Bent the valves . Fixed it and put it back together . No start .
  4. #64
    Sthrn NH/Eastern Ma
    Hmmm. Just throwing out an idea.... Backfiring would suggest that somethings out of time. You sure you have the cams in the right order?
  5. #65
    Newark, DE
    Quote Originally Posted by Steve '92ES View Post
    Also please elaborate on running condition. That is, it sounds like u have fuel, spark and air. Your compression is good. That leaves the check list in the fuel section of service manual.
    Steve may be on to something... If cams/valves are off it will be off proper time. Tell tale sign is if it continues to run/sputter after you kill ignition. But on interference engine I would minimize any engine running out of time.
    Sent from garage
  6. #66
    Jan 2011
    az
    I just checked the cams . The are in the correct order. I know the engine has fuel , and spark. How do you check for air ??
    Also , as for the running condition , all it does it crank and crank , then it sounds like it wants to catch then it backfires . I was always told if a car backfires its out of time .
