Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 153
Thread: Highest recorded top speed of 3/S? Has anyone ever broke 200mph...
    Banned J. Fast's Avatar
    - O - SIX -
    Colorado, USA
    ...gps or video supported. How much road do you think is required for a 3500lb 3/S to break 2 bills...
    ...with 500whp (or is that not enough to get there)?
    ...with 600whp (or is that not enough to get there either)?
    ...with 700whp?
    No hills, no headwind, SAE conditions... dont care about fuel. Has it been done? What do you guys think minimum hp required to get it done?
    BTW, the highest documented top speed I can find on record is Hennesy. He recorded a top speed of 177mph in 1991.
    I've read the top speed thread at 3si and yada yada... seriously though. Has anyone gotten close?
    Delaware
    Ive been close, got scared when seeing the stock hood an inch in air at the fender. I went near 190. Had the power for more. DR650s, DR2 heads, 22psi, trapped 125mph, so probably 450-475 wheel.
    Car was fairly stable, steering was feeling light. Rear wiper bouncing off hatch. Front wipers an inch or so off the windshield. Side glass 1/2 gap off the door seals.
    Jason
  3. The Following User Says Thank You to JasonY For This Useful Post:
  4. #3
    Medford OR
    Matt Monet from 2001
    i have pulled me 93 to 7300 in 5th(a little under 200mph), and my 95 to 6700 in 6th (about 216mph)
    and my viper to 6100 in 5th (down hill) about 201-202mph
  5. The Following User Says Thank You to RealMcCoy For This Useful Post:
  6. #4
    What it is? Not Verified
    I remember a member on the other forum had a gps confirmed speed of just over 200mph, that was awhile back though, I'd have to search for the post.
    92' Stealth R/T TT-DR-650s, Greddy FMIC, MAFT, SAFC2, Greddy profec B spec 2, HKS turbo timer, Dejon pre-turbo intake pipes, PST aluminum driveshaft, Maximal Tcase bracket, 25 spline trans, Fidanza Flywheel, Spec stg 3 clutch, 3sx underdrive pulley, Solid motor mounts, 550cc injectors, Walbro 255, Fuel lab FPR, Fuel rail loop, braided fuel lines, plenum spacer, Borla catback, Megan DP (giggidy ), gutted precats, 19" SSR D5Rs, Drilled/slotted rotors, Tein S Techs, Aluminum STEALTH door sills and spark plug cover, Dual ARM-1's, Autometer gauges, Front mount oil cooler, 3sx dual pass radiator w/ flexlite fans, RFL BOV.
  7. #5
    - O - SIX -
    Colorado, USA
    Here's some stuff I dug up from Norwood Autocraft Aerodynamics regarding the subject matter.
    Quote Originally Posted by Norwood
    The Aerodynamics of Drag and Power
    Aviation people distinguish air resistance as parasitic and induced drag, but the critical thing to understand is that drag increases as the square of speed. That is, while power increases in a linear fashion, drag increases exponentially with speed, in a parabolic function. For example (neglecting the effect of rolling resistance), if 100 horsepower would push a certain vehicle 100 miles per hour through the air, doubling the speed to 200 would require two-squared or 400 horsepower to overcome air resistance, while 300 miles per hour would require 900 horsepower.
    Components of the following formulae which can be used to compute power required to achieve a certain speed in a vehicle:
    Power = 8.702 x 10**(-6) x Cd x A x V**3
    where Cd = coefficient of drag (look it up for your vehicle)
    A = square feet of frontal area of the vehicle
    V = Velocity, in miles per hour
    The 8.702 x 10**(-6) section of the equation is a slightly-fudged correction factor made up by me to account for air density, gravity, rolling resistance, etc. Bell uses 6.7 x 10**(-6) x Cd x A x mph**3 and adjusts for actual rolling resistance, where
    Rolling Power = 4.0 x 10**(-5) x weight x mph
    Cd is adjusted to include rolling resistance (a relatively flat function), and air density is assumed to be standard Temp. and pressure at sea level. Intuitively, power required to achieve a certain speed is dependent on how good a shape the vehicle has (coefficient of drag), how big the shape is (frontal area), and how dense the air is.
    Working through an example, Bill Gordon’s Norwood Autocraft 8.2L 288-GTO 308 conversion, assuming a Cd of .33, a frontal area of 20.5 square feet, and assuming a target speed is 200 mph. Therefore,
    Required Power = (8.702 x 10**(-6) x.33 x 20.5 x 200**3
    Required Power = 0.000008702 x .33 x 20.5 x 8,000,000
    Required Power = 472
    Observed results when Norwood was running the car with a super-high-output naturally-aspirated 302-inch Chevrolet small-block engine were that the estimated 550-600 plus crankshaft horsepower took the car to 199 mph. Norwood says experience indicates it takes almost 600 crankshaft horsepower to break 200mph, a rule of thumb born-out yet again when a Norwood Toyota MR2-turbo set a record in the 1.5-liter blown modified sports class after it attained 207 mph on 465 chassis dyno rear-wheel horsepower, an estimated 585 at the crank.
    Another formula computes power required to increase to a new higher speed:
    New Required Power = Old Power (New Speed/Old Speed)**3, where Old Power is total available rear-wheel power.
    For the 288-GTO to attain 300 miles per hour,
    New Power = 472 x (300/200)**3
    New Power = 1593
    In another example, lets consider the same car with the frontal area reduced by decreasing the height by one inch (which can often effectively be achieved by lowering the car). In round numbers, assume frontal area is decreased by .5 square feet. This reduces power required to break 200 in the GTO to 460 at the wheels, meaning crankshaft horsepower required to break 300 is reduced by about 55.
    Lowering the entire car has a direct effect on the frontal area multiplier, and is why you see speed record cars virtually scraping the ground. Lowering the GTO even one inch reduces frontal area roughly .5 square feet, reducing the frontal area multiplier to 20 square feet, which reduces required horsepower to hit 200 to 460, or 12 rwhp less. The point is, the effect of reducing drag pays far greater dividends on top speed than adding horsepower. It is standard practice to remove the side-view mirrors from “unmodified” cars before top speed runs.
    The above equations assume that a vehicle’s the torque and power curves are optimized for the application—that is, that the powerplant is mated to a gearbox that enables the vehicle to be at or very near its peak power at the target potential top speed. Naturally, the vehicle's cooling system must keep up with thermal loading at wide open throttle long enough to reach the target speed, the tires must maintain their integrity, and so on.
    Of course, most enthusiasts are more interested in road-racing-type performance than top speed, in which case the large down-forces needed to hold the car to the road on high-speed turns becomes essential and a necessary tradeoff against the added drag of the down-force wings. Good rear wings and frontal splitters and canards can add thousands of pounds of down-force at speeds over 100 mph, but they also add hugely to drag. You've heard it before, but there's no free lunch in aerodynamics either.
    From the records I could find from the Russian's conducting their wind tunnel tests the Cd of the 3K is 0.389? Can that be confirmed? And what is the OEM frontal area? Has anyone ever calc'd that?
    I think using Norwoods theoreticals as a baseline would be a good place to start. I liked their data. Looks like you need north of 500 to the wheel at first glance. I think once we dt the frontal we'll get a clearer picture. Anyone have some quick measurements for height and width? Outside front tire to tire and from ground to top of roof?
  8. The Following User Says Thank You to J. Fast For This Useful Post:
  9. #6
    - O - SIX -
    Colorado, USA
    OK 3S Wiki... love it!
    A wind tunnel test in the Russian Magazine "AutoReview" has confirmed that the active aero is indeed functional. At speeds of 144km/h, a GTO with the active aero in the standard position has a lift force of (97Newtons front / 196Newtons rear), or (21.8lb/44.1 lb). That same car with the active aero elements engaged produced a lift force of (10.6lb/-10.6lb), for an equivalent zero-lift. At speeds of 200km/h, the change was more drastic with (50.8lb/102.5lb) disengaged versus (24.7lb/-24.7lb) engaged. This decrease in lift comes at a very small penalty, as the drag force at 144km/h only increased by 1.3lbs, from 140.7lbs to 142lbs. This was achieved by a decrease in the coefficient of drag (.390 to .389), with only a slight increase in frontal area (2.009m^2 to 2.029m^2).
    Using this data and the Norwood formula I summize:
    2.029M^2 converts to 21.84ft^2
    Setup looks like this...
    Required wheel horsepower to achieve 200mph = 8.072 x 10^-6 (x) Cd (x) Area(sf) (x) 200mph^3
    Required wheel horsepower to achieve 200mph = 0.000008702 (x) .39 (x) 21.84 (x) 8,000,000 = 593whp
    Answer = 593 uncorrected wheel horsepower.
    How many guys do we know have an actual 600+ uncorrected whp car?
  10. The Following User Says Thank You to J. Fast For This Useful Post:
  11. #7
    oct.2007...
    I feel under car aero dynamics is largely over looked with this platform where as cars like the nsx,gtr,s2000 and others get under tray parts that have extensive wind tunnel testing to ensure they reduce drag and improve down force.
    "J.Fast" are you looking into this area with your racecar build?
  12. #8
    oct.2007...
    I was just thinking I know theres gotta be dr750 cars that "could" do 200 mph with the right setup (maybe lower ride height?)
  13. #9
    - O - SIX -
    Colorado, USA
    I dont know man, that's a long time to stay in it with a tiny ass hotside. I bet that shit knocks around 160mph and gets exponentially hotter with every increase in mph where the RPM's climb real slow.
  14. #10
    - O - SIX -
    Colorado, USA
    To the guys saying they broke 180mph, hell even 200mph. Today, I pointed my car east and dropped the hammer 3 times for 8 flat and straight miles. 186mph... that was all she had and my SAEwhp is 720whp. So... I'm asking what's going on with the 180+mph guys and inquiring about those who claimed breaking 200mph.
