Results 1 to 10 of 10
Thread: 92 Stealth R/T
    92 Stealth R/T
    I just bought my first 92 Dodge Stealth R/T and a some ?s. OK the back of the car the bumper says R/T it has flip up head lights not one piece black leather seats I know its non turbo its a 3.0 dohc I have not drove it I am buying it because the lady said the motor is tapping I started it and it has a little noise almost like a honda sounds all the time but then it stopped and came back it sounds like a idler wheel or the bearing for the belt and also she said its fwd why is it a R/T but non turbo and non awe is there aR/T turbo and fwd or awe and if this car is fwd can I swap a awe system into it and does that require a different tranny
    I'm Kind Of A Big Deal
    The R/T non turbo is a FWD car. Only the Twin Turbo model is AWD.
    You can make it AWD, but it is extremely expensive, and very complicated. It would be cheaper and easier to sell your stealth, and buy a R/T Twin Turbo.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    How much u talking to do it did they ever. Make a stealth AWD with AWS
    we've done a few AWD conversions. It is WAY too expensive to also do an AWS conversion. You're looking at around $4000-5000 in parts and labor just for the AWD conversion. That does not include doing a twin turbo engine swap.
    i said the same thing in response to your first post. you have no relationship with this car. if you want awd, you're much, much better off just buying one that is awd. em and i both have experience in that route; it's not worth it unless you are sentimentally attached to the car beyond financial reason.
    p.s.
    all AWD 3/s's up to 1994 had AWS. and it sounds like lifter tick, from the way you describe it.
    To add that IPD's P.S. All 3000GT VR4's had AWD and AWS. All 91-96 Stealth RT/TT's had AWD. 91-94 RT/TT's had AWS and it was deleted on them for 95 and 96.
    OK well I will stay fwd lol also my motor 3.0 dohc is 222 HP can if I boost it put a bigger fuel pump in and injectors how much boost can u run in the bone stock block Max
    Do some reading brudder. There is a whole section on this very forum dedicated to forced induction upgrades on a NA.
    I am having trouble even using this forum lol where do I find it
    Go to the main forum page www.3sgto.org/forum.php
    Midway down the page you will see the Non Turbo engine forum and below it the Upgrade time forum
    Upgrade Time - Turbos/Supercharger
  11. The Following User Says Thank You to stealthee For This Useful Post:
