Results 1 to 10 of 19
Thread: How to prime the engine?
    Jan 2011
    az
    How do I prime her? I once read that u can un hook the cas sensor and crack? Bad idea?
    Prime the oil? If so I unhook my fuel pump. Mine is hot wired so I just pull the fuse.
  3. The Following User Says Thank You to green-lantern For This Useful Post:
  4. #3
    I second this
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
  5. #4
    just pull the eci fuse in the main fusebox under the hood. that will ensure it isn't going to start at all.
  6. #5
    Put it in gear and push it with 10 people with the ignition off. J/k ^ or if you have EMS turn off all 6 injectors
  7. #6
    Oct 2010
    Coatesville, PA
    Remote starter will work as well...
  8. The Following User Says Thank You to ICPREY For This Useful Post:
  9. #7
    Warner Robins, GA
    1. Remove all plugs
    2. Hook up remote starter
    3. Crank continuously for up to 1 minute or oil pressure reads over 25 psi.
    4. Repeat step 3 twice more.
    I usually get 30-35 psi oil pressure when cranking without plugs in. If you don't have a mechanical oil pressure gauge, put one in for the duration of priming.
  10. #8
    Jan 2011
    az
    Ok thanks. I'll just take the eci fuse out, unplug cas, and unhook my fuel pumps and crack! Thanks bros.
  11. #9
    Jan 2011
    az
    Quote Originally Posted by BaadVR4 View Post
    1. Remove all plugs
    What you mean by remote starter?
  12. #10
    Warner Robins, GA
    It's a push button switch that you can use to apply power to the starter without using the key. Available at auto parts stores/Sears/etc. Hook one alligator clip to the power lug of the starter and other alligator clip to starter solenoid terminal and voila! Remote starter! Most of them have 5-6 feet of wire so you can sit behind wheel and crank the engine without having the key even in the switch. Works great.
    Quote Originally Posted by keo92stealth View Post
