I bet a 4L with twin GT35's could run mid/upper 20's boost on 93. Like mentioned, most of these setups are much more efficient on the exhaust side of things than most of our cars. "big" to us is still TD05 or T3 with a small a/r.
Jason
Jason
Since we are comparing the 3s to other platforms I would simply say that the head design plays a huge part . Someone should post some stock flow numbers between different heads .
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water -- DFW / FLW Flow Files for use with Engine Simulation Software
Check that out, a vr-4 is on there as well as mostly everything else. 242/212 @ .400 and 28 inches. Jrod's head guy claims 304 intake after their work, DR probably similar.
3SNG15 Best overall
Runs 12's (12.98's!!!!!!)
My Garage
To my knowledge, the 3S heads really aren't that bad. The 300zx heads flow worse and they have two log style exhaust manifolds. Major factor would be that they have two bigger Turbos. A BPU 300zx makes 400-425 wheel at low 20-something psi. They don't hold that to redline tho. Restrictive hotside lol
Sent from my DROID BIONIC using Tapatalk 2
Has anyone done a dyno on Mivec heads with pump gas? I know Itallo and the guy with the Eclipse Mivec 3.8L motor have both made 800-1000AWHP plus on race gas or ethanol, but I couldn't remember what they were able to run on pump. Unported those Mivec heads flow better than our Stage III heads iirc. I know ported with bigger valves the Mivec flows better for sure. Both of those owners have bigger manifolds, exhausts, intakes, intercooler pipes, etc to make a more efficient setup. If they can't run more than 20-23 psi, then there's something else holding us back or it just isn't possible due to the inefficient design of an older V6 compared to a new 4-cylinder.
thats what i was saying earlier when i posted the vid (leonels car). him and italo have the same setup except italo has slightly different turbos and mivec. bottom ends and manifolds are the same iirc. thats kinda why i lean on cams being the culprit because many people have changed every other variable but as anyonebutme always says, there are no truly *good* cams made for our cars yet. you are almost certain to not gain max potential power with just a cam swap unless you put adjustable cam gears on there too. i wish someone on here had the pull to investigate into getting cams made and swapping them in for direct comparison
After so much effort and work that has been put into developing the Flash ECU for our platform, making and testing a set of cams should definitely be doable. EVO's regularly pick up 40whp with a cam swap with supporting mods. We've also got quite a few technical savy 3/s gurus still with the platform...its just a matter of time IMO.
Back in 2002 Carroll Smith showed up at a race I was at. I ran into him and convinced him to come look at my car (the Talon) because in the space of 24 hours it had gone from a championship winner to undrivable at the same track, same weather, same tires and I was at my wit's end figuring out why.
Carroll looks at the car and starts asking me questions. I have NO answers. Lots of "I think this" and "the general consensus on the Internet is this" but nothing specific to my car.
After 20 min of bullshit and blank stares, a visibly frustrated Carroll says "dear God man, you're supposed to be the engineer here. If you don't know these answers, how the hell am I supposed to know?"
It was like being shot in the head with a diamond -and revolutionized my approach to car setup. Suspension got measured and modeled. Sensors got added and logged. Shocks and springs were measured and dynoed. You name it, I did it - and I learned a shitload about suspension tuning, including highlighting all the stuff I (and most other people) got wrong (and discovered too that most shock companies made shit and had no idea).
I very much support this topic; I'm moving to New Brunswick this summer and will lose access to Sunoco 94. I'm going to have to re-tune the car for 91 octane and I'm keen to see what people find.
But if you are gonna do it, do it right. Wanna know the difference between the EVO head and the 3G? Buy an EVO head and break out the calipers. CC the combustion chambers. Make rubber casts of the head passages and compare them. Slice up those casts and compare sectional area and shape. Break out the band saw and cut some heads open, look at wall thicknesses, look at coolant flows. Build a flow bench (or rent time on one) and get real flow numbers you can trust. Measure cam profiles. Detail every way that the heads differ, and every way that they are the same. Grab some stock intercooler pipes, compare length and volume. Etc etc etc.
I have some books from the 80s that do this with Pontiac motors (real Pontiacs, not the Chevy stuff) that details the similarities and differences between every single engine Pontiac ever made - head castings, camshafts, cranks - the works. Flow numbers, valve sizes, port shapes, chamber CC for every single head casting. All cam specs for every single OEM cam part number. And this predates digital publishing - these books were put together the old fashioned way, with scissors, typewriters, and rubber cement before going to camera and Linotype. Those old skool guys had their shit wired; they were working when it was much harder to communicate, they did it in less time, and in some cases, with smaller production numbers from which to source examples (not a whole lot of RamAir IV parts to measure, and they even had details on the prototyped - but never released publicly - Ram Air V)
Why the Import guys never did this sort of stuff is beyond me... but there's no reason why the 3S crowd couldn't start.
If you are really serious about learning this stuff, start measuring parts and publishing your findings, instead of working off rumour and innuendo.
DG
A guy here in Melbourne bought a set of dr750s removed the exhaust housing and used a modified set he made by 9383464 a band around the hot side and machining the exhaust port larger. Haven't heard if he has dyno results for it though. Someone needs to do this and do a back to back comparison.
Sent from my GT-I9300 using Tapatalk 2
Waiting install
Build Thread
