I know this is a sensitive topic for some, but I'd like to get a discussion going. There are many that say pump gas is a waste of time. Well, I for one like to be able to run times at the track that fully represent my "street" mode that the car sees daily.
If that is not your cup of tea I am not here to argue with you.
The point of this thread is to talk about the reasons why we are stuck at much lower boost levels than other platforms on pump and what can be done about it. What about our engine or cylinder head design is lacking that causes us to have to run so much less boost than say an Evo? Many say that cleaned up combustion chambers like DR or other heads help, but there has really been not much evidence posted to support that.
I know our stock timing map may be too aggressive for high boost, but then we hear from many that running high boost and low timing doesn't work either. I also know that the whole real point is airflow, but it is easy for most of us to get on the same page if we talk about boost.
Basically the threshold for knock on typical 93 octane gas seems to be as low as 15 PSI for some and maybe low 20s for others. Most people do not seem to venture much about 15 lbs, but that really holds us back.
If you don't want to talk about boost then you can think of it in terms of power. Most cars seem to do well to get to 400-450AWHP with bolt on style turbos and pump gas. What can we do to get past this?
Let's pretend these 3 options are off the table at the moment:
1)Methanol/water injection
2)Race Gas
3)E85
What can we do then?
