Page 25 of 25 FirstFirst ... 15232425
Results 241 to 247 of 247
Thread: My full-car build
  1. #241
    Back at it after getting the 99 road worthy again.
    I think I can see the light at the end of the tunnel....
    Sent from my SM-G998U using Tapatalk
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
  2. #242
    Waiting on some packages for random misc things needed to button it up, buuuutttt
    It's almost ready to start!
  3. #243
    The big single turbo, the easy access to the rear plugs. Looks amazing.
  4. #244
    If you rather watch the car go together over photos...
  5. #245
    Jan 2021
    With all the thousands of dollars of super out of this worl performance parts you are going with an OEM timing belt? I find that hilarious...just kiddin
  6. #246
    There's really not anything better than the OEM timing belt. As it is the belt itself is very rarely a failure point. The things that usually fail are the water pump, idler pulley, or tensioner/tensioner pulley. The belt may fail if one of those fails, but it's not going to fail unless there is another issue. None of those parts should fail is proper preventative maintenance is done, ie the 60k services.
  7. #247
    Wired up the car and powered it on for the first time in 9 years. I extended and shortened wires on the factory harness to be able to try to start it as close to stock as I can.
