Page 4 of 25 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 247
Thread: My full-car build
  1. #31
    Just got around to testing my stock PCV valve. I've been meaning to for a while. It held to 20 psi and barely started leaking, I mean I could barely hear it. I ran it up to 30 psi and it leaked about the same, almost nothing. So I know I don't have to worry about that.
    Edit: Oh and OP, sorry to sort of hijack the thread. Thought you would want this info anyway.
    Yep, I don't mind. Especially because more people are subscribed and you guys keep bumping it haha.
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
  2. #32
    Quote Originally Posted by Unknownvr4 View Post
    Bump
    Man vs 3/S verified
    Kingston, WA
    Not sure if this will solve any issues for anyone but I tested the clutch booster one way valve today and it held 80+ psi, ZERO leakage, none.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
  4. #34
    Explain please
  5. #35
    The Panda Not Verified
    Washougal WA/Portland OR
    Explain please
    The clutch booster has a hose with a one way check valve located on the drivers side between the firewall and the engine connected to the corner of the intake plenum. That valve held 80 psi. When pressure tested. I think Nate is saying that this may be a good alternative or replacement valve for the PVC.
    Does this explain it?
  6. #36
    Quote Originally Posted by vr4tune View Post
    I thought that's what he was talking about. I don't think I have one because my car is a Base converted to TT AWD. I'd like to see a pic of this valve.
  7. #37
    Haven't posted in a while but I've been collecting parts (for both of my cars )
    Here's where I'm at right now and I should be dropping the engine back in this weekend and putting the trans back together.
    First one with the setrab/maximal performance oil cooler kit!!
    Setrab core vs stock
    SCE Torsen center diff and 300m output shaft
    Completed front valve cover and and new hks oil cap
    Also I just had my bellhousing brace welded in but I don't have a picture of it right now..I also have the sheet metal for my radiator ducting
  8. #38
    oct.2007...
    Cleveland, Ohio, United States
    man that sce torsen center diff is sexy
  9. #39
    I really like Terry's oil cooler.
  10. #40
    I forgot to post this picture a while back..
    I'm just waiting on building the trans which I should be able to do on Wednesday..
