Results 11 to 20 of 38
Thread: N/A Cams VS TT Cams. Benefits from mixing?
    Never finishes any verified
    Wake Forest, NC
    Also, if using adjustable cam gears and if we followed the Cam Gears set at +1 advance on intake, -3 retard on exhaust. Then with N/A cams you would set the Cam Gears at +1 advance on intake, -5 retard on exhaust. That correct??
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Wake Forest, NC
    Ha, you beat me typing it out.
    Jan 2012
    Pittsburgh
    well it didnt take long for this to get wrong info
    edit: even i was wrong lol
    Medford OR
    Quote Originally Posted by 3000gttom View Post
    Link to your source of "correct" info...?
    I'll post mine when I get home from work in about an hour....
    Jan 2012
    Pittsburgh
    TT and N/A cams are the same profile.... TT exhaust cams are retarded 2 degrees to INCREASE overlap.
    lol just think about this statement... if the TT cam is retarded then overlap definitely is decreased lol... i like the way you made your mistake all caps
    edit: lol i was wrong about this, but TT runs less over lap not more
    edit 2: this one is pretty embarassing, tt does have more overlap and a bigger overall exhaust cam
    Jan 2012
    Pittsburgh
    i do believe they are all .350 lift im not sure if the tt exhaust is a smaller duration or if they just shifted it a couple degrees though
    Medford OR
    No mistake on my part.... I'm right and I can prove it. Care to make a run at proving me wrong while I'm driving home...?
  8. #18
    Jan 2012
    Pittsburgh
    wait yea i thought about that backwards lol, retarding exhaust means more overlap that parts right... but the tt car runs less overlap than the n/a <<im wrong here
    on stealth 316 its say intake cam is 251 degrees and exhaust is 247 degrees
    but who knows... ive seen a million threads on this and everytime there seem to be multiple answers to the question lol...
    the safe bet would be to use the TT cams with the TT car and NA cams with the NA car...the 4 degrees duration you might get on the TT exhaust (if thats even correct) and needing to buy cam gears probably isnt worth the hassle
  9. #19
    Medford OR
    You should quit while you're behind.....
  10. The Following User Says Thank You to RealMcCoy For This Useful Post:
  11. #20
    Medford OR
  12. The Following User Says Thank You to RealMcCoy For This Useful Post:
