Results 1 to 8 of 8
Thread: 1993 3000gt vr4 $8500
    I'm Kind Of A Big Deal
    1993 $ 8500
    We are selling a 1993 3000GT VR-4, black with red leather interior. The drivetrain and modifications are from a lower mileage 1992 Stealth Twin Turbo that we had worked on for a customer. Everything was transferred over to this 1993 VR-4 approximately a year or so ago. We are asking $8500. Modifications are listed below.
    Forged crank (block itself is a 2 bolt)
    new pistons
    16 t turbos
    550cc injectors
    stage 3 racing clutch (Southbend)
    aluminum radiator
    greddy type s style bov
    k&n intake
    aem wideband 02
    Ksport control pro coilovers
    turbo xs manual boost controller
    autometer sport comp vac/boost gauge 30 psi
    walbro fuel pump which is hot wired
    carier bearing bushing
    down pipe with ultra high flow cat
    both front axles
    center supporting bearing
    rear subframe
    oil cooler lines
    carbotech bobcat brake pad with rotors
    stainless steel brake line
    broomfeild billet transfer case housing along with 300m output shaft
    power coated blue valve cover
    dejon pipe with gm maft in blow thru
    tanabe gblue concept exhaust
    ngk iridium plugs and wires
    If you have any questions, or would like additional pictures or information, please don't hesitate to email, PM, or call us.
    (610) 438-0439 M-F 9am-6pm
    3000GTStealthWarehouse@gmail.com
    Thank you,
    Emilie
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Stuper Moderator
    January 2003
    How many miles on the odometer? How many 'low' miles on the Stealth bits that were transferred?
    Douches
    I don't know off hand, I'll find out and post up
    It wasn't as low mileage as I thought, we had just been working on the car since about 70k miles or so.
    94,000 on the engine when we rebuilt it (new piston assembly, forged crank, steel head gaskets, etc.), same on the trans, etc.
    the mods only have about 4k miles on them or so. The odometer was transferred over to this car, so it currently reads 97,xxx.
    I do not know the mileage on the chassis, I will try to find out, and post up.
    Nice looking car.
    Mileage on the chassis is 150k... but there isn't much on the car that has 150k on it.
    It doesn't have an Emanage Blue, but it has a MAFT. Not sure how the emanage got on that list haha.
    Sold!
