I noticed this while I was installing my arc2 awhile back . This is pin 72 or the tps ground . But as you can tell its been cut . Baught the harness this way . And I also know that its not a ground for just the t ps but a few other important sensors . I need your guys help on this . Should I just try my luck buying another harness or trace this and find out where the rest of the cut ground wire ended up .
