Results 1 to 10 of 18
Thread: Black Stealth LCD install
    I've had quite a few people ask me for info so thought I'd go ahead and post this here. If people still want me to install it I guess I could be persuaded but I'm busy these days so I'm not too eager to do it anymore.
    Info on taking the cluster apart
    http://www.3sgto.org/f2/how-remove-t...ter-10625.html
    Starting off, I did cut these out before with a die grinder and cutting wheel but some dykes and needle nose pliers works better and doesn't get a bunch of plastic dust everywhere.
    You want to grind this pin down some. Hard to fit it in if you don't.
    Next cut the plastic piece behind the tach face. I cut this one to high but it doesn't hurt anything. You only need to cut to the bottom of the hole not the top.
    Take that nice new LCD screen and grind it up like this lol, you might need to shave the bottom a bit more later. Be careful not to go crazy when doing this. You don't want to damage the LCD.
  2. The Following 3 Users Say Thank You to green-lantern For This Useful Post:
  3. #2
    Now the tedious part, mark it like this with a straight edge.
    You need a piece of wood with thin cardboard. drill a hole for the peg.
    Use a straight edge and an x acto-knife to cut the part out. Be careful and score it some, take your time because you will be looking at this hole every time you drive the car. You don't want it to be ugly.
    Use a putty knife and screwdriver with sandpaper wrapped around them to make the hole as perfect as you can.
  4. #3
    Use a vice to hold the LCD. Put superglue around the top of the black part of the LCD then just set the gauge face down onto it carefully. I like to light it up so I can get it straight as possible. Don't go crazy with the superglue, it can stain the screen if you use too much.
    Cut a place for the wires to come out. Test fit it some, grind trim anything that is putting it in a bind.
    Then just put it back together
    If you have any questions just let me know.
  5. #4
    Great guide, this is what I followed.
  6. The Following User Says Thank You to FeaRpb For This Useful Post:
  7. #5
    Thanks, I put your link in there also. good info
  8. The Following User Says Thank You to green-lantern For This Useful Post:
  9. #6
    Dad verified
    01 Apr 03 - Jokes on me
    NJ
    Still doing this service? And how much was it again?
    Sent from my Nexus 7 using Tapatalk 2
  10. #7
    3SWiki.org
    10+ Years
    The Silver State
    Nice guide, man! Thanks for taking the time to do this.
  11. The Following User Says Thank You to stealthify For This Useful Post:
  12. #8
    Quote Originally Posted by stealthify View Post
    Thanks, I might of left a few things vague but if anybody has any questions I'll try and clear it up. I'm just expanding Antero's instructions a bit.
  13. #9
    One fix at a time verified
    Kansas
    I wish I would have thought about using sandpaper after cutting out the hole when I did mine. Nobody comments on it in the car but I can tell the hole isn't as straight as it needs to be. Even using a steel ruler and a brand new knife you still have to be very very careful when you're scoring it. I think I rushed it too much or I could have had a better product. I also installed my rotary knob in the ECS button location. I used some of the stock parts sent with the lcd bc but boy it sure was a pita getting the board mounted in the black box that housed those two buttons without losing the functionality of the buttons. I would do it over again if I gave it some more thought. There isn't as much to grab ahold of with the ECS button as there needs to be.
  14. #10
    Yeah I didn't use the sandpaper when I did mine but I got it good enough where it didn't bother me. When doing others I thought about the sandpaper.
