Results 1 to 10 of 15
Thread: Clutch adjustment = no need for trans rebuild!
    No BS Feedback Score 0 hotGTO's Avatar
    Sorry if you care, I could be lying anyway!
    NJ (south)
    I was grinding 2nd and shifting was way too notchy and I started getting blocked out of gears and grinding all gears and really having to fight to shift under all circumstances... then I adjusted my clutch to engage farther from the floor, and it fixed everything, and it shifts like new now! SO happy it does not need a trans rebuild!!!
    Dave
    91 Stealth TT- Pampena Stage 2 short block, rebuilt heads, Solid mounts, MBC, Vac reduc, hotwired, Blitz FATT, 4.5" FIPK, TurboXS BOV, Stainless Downpipe, Race pipe, Borla exhaust, AHDS, 500 lb clutch, JDM 25 spline 5 spd/tcase, Short Shifter, EVO leather knob, 18" Mazdaspeed wheels, Front Splitter, in dash touch screen bluetooth/navigation/DVD...
    94 3000GT DOHC - Nitrous express proton series w/ upgraded solenoids, dash mounted datalogger, in dash touch screen navi w/bluetooth, IPT end clutch, high performance trans cooler, Translab shift kit. SOLD
    VR-3747 :D Not Verified Feedback Score 1 (100%) futurevr4man's Avatar
    Dayton Ohio
    wierd. was it not disengaging all the way? was it engaging like a cm off the floor or something?
    NJ (south)
    Yes, I had to pin the pedal to the floor to shift, and it would start to engage as soon as my foot started to lift. That's why I had to adjust it, I knew it was not supposed to engage so low. After adjusting it to where the engage point felt right around the 1st 20% of the uptravel, and she shifts like butter now... Sigh, the small victories are nice...
    Texas
    Any references for anyone that needs to do this?
    NJ (south)
    http://www.3si.org/forum/f12/clutch-adjustment-310609/
    Sorry to use a thread from another forum, but at least now we have the info here too... LOL
    XLR8TOR Feedback Score 0
    Las Vegas, NV
    Attention 3S Owners: Read this first before you attempt ANY clutch adjustments.
    This is a direct link to an article at the Stealth316 site.
    http://stealth316.com/2-clutch-bracket-bolt.htm
    This link details a problem I ran into several years ago and everyone should be aware of the problem.
    Texas
    I will take some pics and throw it in here when I do mine today or tomorrow.
    NJ (south)
    This is from the thread I referenced earlier... I don't know the creator of the image, but it was perfect for helping me adjust mine properly...
    What you see is looking at the clutch pedal linkage under the dash next to the clutch pedal, and it is upside down as if you are laying on your back...
    Loosen the lock nut and turn the shaft at the grooves using a needle nose pliers then tighten the lock nut again... turning clockwise raises the engage point...
    Texas
    Yeah, sorry, I still haven't got into a position to even check my clutch engagement yet.
    NJ (south)
    Quote Originally Posted by blindmist View Post
    LOL, I revisited this and realized I had not told anyone how to do it for themselves, so I hope it's a better thread now... Thanks for the nudge!
