Page 3 of 48 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 472
Thread: Slightly tweaked 3000GT TT
    Oct 2011
    Sundsvall, Sweden
    Instead of replacing the whole rear wing of the car (as I had first planed) I managed to pull out most of the dent using small pieces of threaded rods that I welded to the damaged area.
    More pics of this operation are available on my website: Unlogic.se - Fixing a dented rear fender on an old Volvo
    Oct 2011
    Sundsvall, Sweden
    My car was in pretty good shape when I bought it. However for some odd reason a few small pieces of the interior where missing.
    One of them was a coat hanger. It proved quite elusive to find but thanks to the member 95_GTO of this board I was able to get my hands on a new set. The color didn't really match the black interior of my car but it'll do for now.
    At the end of the summer my shift boot started falling apart literally overnight. According to 3SX this seems to have something to do with the material used since even the new replacements from Mitsubishi seem to suffer from this problem.
    Quote Originally Posted by 3SX
    9/4/12 - Due to the fact that most of the recent OEM shift boots have been either 1) arriving to us with cracks in the vinyl and being sent back before ever shipping out, or 2) arriving to you our customer and cracking within a month after installing, we are no longer offering the factory shift boots.
    After some searching on this board I found a positive review of bonniebbuttons who sells leather shift and hand brake boots. I can really recommend these, they fit like a glove and don't too much either.
    The old shift boot turned inside out.
    The new one installed.
    Removing the hand brake boot.
    Hand brake boot installed too.
    Oct 2011
    Sundsvall, Sweden
    Time for a little custom fabrication...
    For some reason my car had no brake light in the rear wing. The cables were there all the way to the trunk. But the connector to rear wing didn't use them.
    Here you can see how the cable going to trunk has 7 cables but the connector to the wing only uses 5 of them.
    Used a multimeter to check if the two "extra cables" were indeed for the brake light and they were.
    Removed the glass on the rear wing and noticed that it was painted with some funky reflective paint on the inside... well problems are made to solved aren't they?
    Bought a few extra bright LED's and some circuit board.
    It's alive!
    Covered it all in hot glue to avoid problems with moisture getting in.
    Tried a few chemicals on the paint on the inside of the glass but nothing helped. As a last resort I carefully removed using a wire brush. The result was clearly not optimal but it will have to do for now. Does anyone have a transparent glass for the active aero wing to spare?
    Bent two small pieces of metal in order to fasten the brake light using the same screws as the glass.
  4. #24
    Oct 2011
    Sundsvall, Sweden
    Everything installed and working.
    Managed to insert the new cables into the same sleeve as the original cables by carefully pulling them in with a piece of steel wire.
  5. #25
    Cool thread, enjoying reading it.
    Oct 2011
    Sundsvall, Sweden
    Here's a few updates.
    Got myself a set of Gene SMIC intercoolers from Jeremy (J.Fast). These have 2 inch pipes so I'm thinking of replacing the stock pipes with a hard pipe kit. Is there any decent options on the market right now apart from the redesigned CX racing kit?
    While I was at it I got myself a new air filter and a aluminum MAF-adapter.
    I did my best to find the biggest possible K&N filter that would fit in the stock location. I eventually settled on the RF-1021 model which clear the inside of the fender and the ABS pipes by about 1.5 cm.
  7. The Following User Says Thank You to Unlogic For This Useful Post:
  8. #27
    Oct 2011
    Sundsvall, Sweden
    When I bought my car it came with a staggered and quite worn set of OZ Racing Futura wheels that I never really liked. And being staggered meant that I could not rotate them after track days which always wore more on the front tires than the rear ones...
    Put out an ad for the wheels and amazingly got them sold within a week.
    Here is what I replaced them with:
    Note that the car is missing the front active aero plastic on the photos. I'm about to replace the engine mounts and install the new intercoolers so that car isn't fully assembled at the moment.
    As you can see from the photos it's not exactly the right season for 3000GT driving here in Sweden right now
    By the way the new wheels are Rota GTR (also known as P45) 8.5x18 ET35.
  9. #28
    i like it.
  10. #29
    YOUUSSS TRROOOLLLIN supporter
    Boston, MA
    this thread. i like it. keep up the awesome work!
    -jeff
    1992 SVX LS-L
    1996 3000GT FWD-TT
    2005 XC90 T6 AWD
    i collect parts.
  11. #30
    Kinda off topic, but I am really liking how compact your lift is. How do you like it?
