Results 1 to 10 of 17
Thread: Does the ecu ground through its brackets in any way?
    Quick question, I am doing some powder coating on the interior center console supports. I dont think they do, but want to make sure, does the ecu or mfi relay ground through their metal brackets at all? I would take my ecu case off and see myself but its rebuilt and under warranty. Thanks
    Learn how to Powder Coat at www.powdercoatguide.com.
    Not that I know of. I have had ECU's just laying on the floor to test things and the car fired right up.
  3. The Following User Says Thank You to stealthee For This Useful Post:
  4. #3
    Twin Turbo verified
    Melbourne, Australia
    I can't comment on ours but usually yes they do. Usually the screws that hold the ecu into the housing are ground points so then the housing is screwed/bolted to the car. I could not change the contact points of any major component.
    Sent from my GT-I9300 using Tapatalk 2
    Waiting install
    Build Thread
  5. #4
    99 ECU's have a plastic case......
    I've run my car with no case or MFI relay grounding before.
    Alright well if anyone knows for sure, please post up. I know for a fact that these cars run with the ecu lying on the carpet. I also know that the ptu is supposed to ground through its metal bracket but I have seen a car running fine with it just dangling there with no bracket at all. Just want to make sure it is right, I know there are grounding wires at their connectors, just wondering if they were designed to be grounded through the casings as well. I thought of the 99 ecus case being plastic, but after looking at some pics of them, they have metal brackets to mount them.
    Quote Originally Posted by 99ishVR-4 View Post
    I know for a fact they don't.
    When you do your coating, keep a bolt in every threaded spot so the threads stay clear. You should be fine if you do it that way.
  8. #7
    So you are saying it needs to be bolts to the brackets?
  9. #8
    Quote Originally Posted by Beef6 View Post
    What I'm saying is use bolts as a way to mask the threads. They also sell high temp plastic plugs which can survive 10-15 in the oven too and work well for masking threads.
  10. #9
    Sorry my last post did not make sense, I meant to ask if you were you saying the ecu needs to be bolted to the bracket to be grounded. I wasn't sure if your reply of "I know for a fact they don't" was agreeing with 99ishVR4 saying that they do not ground through the bracket or saying you know for a fact they do not run if not grounded by the bracket. Sorry for the confusion I just wanted to clarify it.
  11. #10
    March 2007
    Muskogee, Oklahoma, United States
    My question is... why would you be powder coating brackets that no one can see anyway?
