Results 1 to 10 of 22
Thread: o2 sensors and fuel trims
    Jan 2012
    Pittsburgh
    hi, i was wandering which of the 4 o2 sensors have what tasks
    i have an n/a dohc and i put headers in and i have a fuel trim code for bank 2, or does any one have the evoscan ID locations for all 4 sensors?
    i have the front o2's with their respective banks but the bank 2 rear o2 is not with its bank because there just wasnt the room on the headers for it
    IIRC Bank 1 is the front, bank 2 is the rear. Sensor "1" is the primary, closest to the engine.
    I.E. "Bank 2 Sensor 1" would be the rear primary sensor.
    Jan 2012
    Pittsburgh
    do the primaries have full control over the trims or do the secondaries also play a part in that?
    secondary O2's are just there to make sure your precats are working. They do no effect fuel trims. You may have to space out your downstream O2's so you don't throw a CEL.
    Jan 2012
    Pittsburgh
    ok good thats what i thought, i just did some logging and my o2's are working just fine, my low trims are around +5 for the front and +11 for the back and mids are +11 front and +12 back
    i reset the trims and immediately they started adding lots of fuel...
    right now i dont think there are any problems with my car other than the headers give more than 12.5% VE more than the stock DP and the ECU is throwing a CEL because of that...i guess i need to learn how to tune the ecu to expect more VE now
    Oct 2010
    St Louis
    Just a quick note, using Mitsubishi notation, Bank 1 is actually the LEFT side of the engine, other wise referred to as the "rear" or the side closest to the firewall. It is commonly though that Bank 1 is the front or right side of the engine, but that is a common mistake. The stock EVOScan locations that EVOScan provides are incorrect.
    www.ClonedECU.com
    Get Chromed!
    1999 3000GT VR4
    Glacier Pearl White
    How To Contact Me:
    eMail: brett_farnam@yahoo.com
    US3S/3SGTO: 99 vr4
    3SI: bfarnam
    Jan 2012
    Pittsburgh
    got my fuel trims to +/- 5% but i still threw a CEL, i guess i'll read it later and see if its the same one or something new
    Jan 2012
    Pittsburgh
    fuel trim is no longer a problem, the codes now are from not having precats... guess i need to find a fix for this now...
    August 2010
    Chicago
    Kinda on topic, but how much a variance in fuel trims is allowable between the 2 banks of cylinders? I'm talking about the lo and mid trims...
    I'd see wonky trims on my stock 98. +6% front low, +2% Front Mid then turn around and see -7% Rear Low and +5% Rear Mid.
    Got me why this is... Car runs butter smooth so it doesn't bother me.
